Questions about lowering my bird - TCCoA Forums
post #1 of 16 (permalink) Old 07-28-2005, 04:09 AM Thread Starter
ScottG29's Avatar
Send a message via AIM to ScottG29 Send a message via MSN to ScottG29 Send a message via Yahoo to ScottG29
I have a few questions about lowering my tbird. I have a 1996 Thunderbird LX Sport. I ordered Ebiach 1.5 inch lowering springs. I did read the tech article on this but I am still unsure of what to do. Before I put the springs in I need to know how important it is to change the sway bar and end links. If possible at this time I do not want purchase a kit. In addition, I am only a mechanic. I am not real firmilair with alignment, camber and toe of cars. When it comes to that I take it in and have it done. Due to lack of knowledge and and alignment rack. Can I just take the car in and tell them to make it right, or do I have to show them certain specs? In advance thanks for the help.
Scott
ScottG29 is offline
post #2 of 16 (permalink) Old 07-28-2005, 04:19 AM
Scott
Some people opt to buy the shorter end links, but from what I read(and did myself) You do not NEED to buy them.
Also alot of places I went for an alignment would not do a lowered car, only stock ride height, so you may have to find a performance shop to do it.
DMcBrideBoston is offline
post #3 of 16 (permalink) Old 07-28-2005, 05:27 AM
Ya theres no need for shorter end links unless you put an aftermarket rear or front sway bar in.
MattsLE97 is offline
post #4 of 16 (permalink) Old 07-28-2005, 08:01 AM
There are no different sway bar links for the front, so don't worry about that at all. In back, a new set of endlinks is about 12 bucks if you get the generic fit (but good quality) Energy Suspension links. The idea is to keep the rear sway bar level with the ground while at ride height.
mercutio is offline
post #5 of 16 (permalink) Old 07-29-2005, 11:15 PM
Teal94BirdV8's Avatar
Send a message via AIM to Teal94BirdV8 Send a message via Yahoo to Teal94BirdV8
you'll probably need new front upper control arms too/ball joints.
94 LX V8 & 93 SC gone. Not forgotten.
1992 Lincoln Mark VII LSC Cobra U/L intake, PP 65mm TB, Powerdyne BD-11 8#, Walbro 255, FRPP 30lb Injectors, MSD ignition, 3.8 Taurus E-fan, A9P MAF conversion, Pypes 1&5/8" Shortys, O/R H-Pipe, 4.10 Trac-Lok, T-5 swap, FRPP flywheel, Ram HDX clutch, Steeda Clutch kit
2002 F150 FX4 Lariat 6" Fabtech, 3" BL, Stock FX4 wheels, 37x12.50 Nitto Trails, Yukon 4.56s, Detroit TrueTrac, Edge Evo, 8K HIDs, PowerStop truck&tow kit
1996 GMC Suburban SLT 6K HIDs, crystal clear light set, daily beater @ 222k miles
Teal94BirdV8 is offline
post #6 of 16 (permalink) Old 08-13-2005, 09:05 PM
Traveler's Avatar
Would that include 89 SC swaybars? I'm looking into a set of those for the Sport.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #7 of 16 (permalink) Old 08-13-2005, 09:43 PM
hmmmmm that i dont know my guess is yes but i'm not totally sure
post #8 of 16 (permalink) Old 08-14-2005, 12:45 AM
As stated above, you don't NEED to change endlinks when lowering the car (type of sway bar doesn't matter here). However, it's standard practice and generally a good idea to use the correct length endlinks in the rear, so that the sway bar ends are parallel with the ground at ride height.
-Rod
post #9 of 16 (permalink) Old 07-07-2006, 11:53 AM
i know this is an old thread, but i was doing a search and this seemed to be the closest i could find. I got the bird lowered and need to know where i can find some shorter rear sway bar end links. i also have the addco 1 3/8 bars waiting to go in, right now with the stock bars the rear isnt sitting level.. thanks
96blubrd is offline
post #10 of 16 (permalink) Old 07-07-2006, 12:18 PM
I found my Energy suspension endlinks at Auto Zone.
mercutio is offline
post #11 of 16 (permalink) Old 07-08-2006, 06:41 PM
and those made it squat back down? what springs are you running?
96blubrd is offline
post #12 of 16 (permalink) Old 07-09-2006, 07:02 PM
No, but even with the long endlinks my suspension wasn't really binding. I replaced them just to get the rear sway bar level with the ground for better geometry. I currently have Bilstein shocks, but they've got 60,000 miles on them so it's either time for a rebuild or a set of Konis.
mercutio is offline
post #13 of 16 (permalink) Old 07-10-2006, 09:32 AM
What is this? http://www.supercoupeperformance.com...spx?PartID=261....
I ordered this along with a bunch of other suspension bushings and they dont seem to be right...
96blubrd is offline
post #14 of 16 (permalink) Old 07-10-2006, 12:35 PM
Why don't they seem right? Too long, or something else?
mercutio is offline
post #15 of 16 (permalink) Old 07-10-2006, 02:03 PM
Stryker's Avatar
i have a 96 lx v-8.i bought the eibachs and left everything else oem.dropped it off at shop picked it up after work my ride sits great and i do not have any weird noises.if you can. upgrade some parts cause that never hurts.if not, you should be good.just my .02
Stryker is offline
post #16 of 16 (permalink) Old 07-10-2006, 07:05 PM
i dont know, I just went and looked under the bird i guess there right.. They do seem to be long but i guess we'll see when they finally go on. I guess i shouldnt second guess the experts. "SHORTER rear sway bar endlinks"
96blubrd is offline
