control arms - TCCoA Forums
post #1 of 4 (permalink) Old 08-02-2005, 12:53 AM Thread Starter
control arms
okay guys I am fixing my upper control arms I ordered them from ford is there any difference from the autoparts store? Also what do I need to replace the lower front arms on both sides can you just buy the whole arm or do you just need the joints? By the way is there adifference in the drivers and passengers side in the UCAs thanks
veyito_169 is offline
post #2 of 4 (permalink) Old 08-03-2005, 11:54 AM
girdnerg's Avatar
This was my front-end rebuild list:
Front suspension:
Upper Control Arm
LEFT - INCL BALL JOINT K8596
RIGHT - INCL BALL JOINT K8598
Lower Control Arm
LEFT - INCL BALL JOINT K80053
RIGHT - INCL BALL JOINT K80055
Strut Rod
Strut Rod Bushing/Kit K8659 Frame Side
Strut Rod Bushing/Kit K8680 LCA Side
Sway Bar Link/Kit K8635 x2
Those are Moog part numbers. The control arms come complete with ball joints, just bolt them in. Both UCA and LCA are different for left and right.
Hope that helps,
Rob
girdnerg is offline
post #3 of 4 (permalink) Old 08-04-2005, 12:44 AM Thread Starter
thanks
post #4 of 4 (permalink) Old 08-04-2005, 07:45 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
Theres no difference between these and the ones you would get from carquest. Previous ones I bought from ford had a clear boot and weren't greasable. The last one I bought had a blue boot and was greasable.
-Rob
-Rob
Rob is offline
