front end - TCCoA Forums
post #1 of 8 (permalink) Old 08-12-2005, 01:11 PM Thread Starter
front end
i have a loud humming noise coming from the front end basically from start and keeps getting louder the faster i go . when i'm on the freeway and turning left the humming stops till i straighten out. i thinks its on the drive side.
bird94 is offline
post #2 of 8 (permalink) Old 08-12-2005, 01:28 PM
02 Explorer Pioneer
timb's Avatar
Sounds like a wheel bearing. When you turn left it is putting more load on the passenger side and less on the driver. Does it get worse when you turn right?
Birdless
timb is offline
post #3 of 8 (permalink) Old 08-12-2005, 01:50 PM Thread Starter
no it doesnt get worse. i just a brake job and the wheel bearing was fine
bird94 is offline
post #4 of 8 (permalink) Old 08-12-2005, 02:07 PM
02 Explorer Pioneer
timb's Avatar
What kind of shape are your tires in? Are there any strange wear patterns or bulges (like a separate steel belt) Tires can give the same humming sound as well
Birdless
timb is offline
post #5 of 8 (permalink) Old 08-12-2005, 03:08 PM Thread Starter
thats what i thought when i had mjy old tires on but i just changed them last month and it still does the same thing.
bird94 is offline
post #6 of 8 (permalink) Old 08-12-2005, 04:37 PM
Litning's Avatar
it is definatly your wheel bearing... I have had 3 go bad in 2 years. They are easy to replace, about 15-20 minutes each side
Litning is offline
post #7 of 8 (permalink) Old 08-14-2005, 09:53 AM
sounds like a bearing problem ....what about the dust shield behind the rotor??? iis it contacting the rear face of the rotor??
Doogie2 is offline
post #8 of 8 (permalink) Old 08-14-2005, 01:16 PM Thread Starter
no their not touching each other i'm going to replace the bearing but i have to wait till next week.
bird94 is offline
