Stock iron pumpkin vs aluminum pumpkin - TCCoA Forums
post #1 of 39 (permalink) Old 08-24-2005, 05:23 AM Thread Starter
doug's Avatar
Is there any other differences, besides the weight, when picking between an 8.8 pumpkin with posi?
I am wanting to convert my open iron 8.8 pumpkin to posi and I have found an 8.8 out of an manual Super Coupe that I am considering purchasing
or
Should I keep on looking for an aluminum unit instead?
Suggestions?
Doug
Current vehicles:
2002 Black Lincoln LX, 1997 Black F-150 LXT 4x4 w/8' bed - 4.2L, 1995 Red & Silver 40th Anniversary Edition Thunderbird 4.6L, 1994 Black Thunderbird LX 4.6L, 1994 Red Thunderbird LX 4.6L, 1994 Silver Thunderbird - carbed 460ci w/C6 (In Progress), 1994 Black Super Coupe - 5 Speed Manual, 1994 Blue Super Coupe - 5 Speed Manual, 1975 Black Trans Am - 455ci w/4 speed, 1973 Black Opel GT 1.9L w/4 speed & AC!!!, 1969 Black Olds 442 455ci w/4 speed manual
doug is offline
post #2 of 39 (permalink) Old 08-24-2005, 07:41 AM
MaddMartigan's Avatar
or
Suggestions?
Doug
The only real difference is weight and even that is slight. If you already have a cast iron pumpkin and you are going to have a limited slip differential put in then that's just fine. The iron pumpkin still has an aluminum cover.
There are a lot of threads about this topic. You may want to do a search and see some of the specifics.
BTW, Ford uses the name of "Trac Lock" and GM uses "Posi-trac" for their respective limited slip differentials.
MaddMartigan is offline
post #3 of 39 (permalink) Old 08-24-2005, 09:17 AM
On Probation
blown96bird's Avatar
I don't think that the small diffrence in weight is worth it. It is only about 7-8 pounds from what I have been told.
blown96bird is offline
post #4 of 39 (permalink) Old 08-24-2005, 09:55 AM
JustinH's Avatar
the aluminum one doesn't get rusty though.
I like it.
JustinH is offline
post #5 of 39 (permalink) Old 08-24-2005, 04:55 PM
I'd prefer an aluminum, but I wouldn't turn down a good deal on an iron one. You can always have it painted or powdercoated if the rust really bothers you.
SloMo228 is offline
post #6 of 39 (permalink) Old 08-25-2005, 01:35 PM
The weight difference is actually closer to 15 pounds. Probably not a noticeable difference. I don't think you'd want a pumpkin out of a manual SC unless you're just using it as a core for a rebuild and gear swap. they only came with 2.72s or 3.08s if you're lucky.
Decy is offline
post #7 of 39 (permalink) Old 08-25-2005, 09:37 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
but if you plan on upgrading the gears anyway, getting a supercoupe unit with the trac-lock from the factory would be easier than buying one and the gears.
wether the weight difference is 6 or 15 it's still weight lost. It's all part of the weigh losing project Im undergoing. Every little thing adds up very quickly. Aluminum pumpkin, aluminum control arms, aluminum driveshaft, skinny front tires, etc.
I have the iron and the aluminum sitting in my garage, I think I'll go weigh them and report back
-Thomas
Thomas is offline
post #8 of 39 (permalink) Old 08-25-2005, 10:02 PM
Uber Luber
Thomas's Avatar
k weighed them both just a few minutes ago.
Cast Iron 3.08 open differential - 81lbs
Aluminum 3.08 open differential - 62lbs
So it weighed in at just under 20lbs lighter than the cast iron. I can lift the aluminum with a little effort, but I had to drag that damn cast iron POS across the floor.
-Thomas
Thomas is offline
post #9 of 39 (permalink) Old 08-26-2005, 02:23 AM
Refrigerator Raider Hater
GreenBird's Avatar
...but I had to drag that damn cast iron POS across the floor.
Time to hit the gym.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #10 of 39 (permalink) Old 08-26-2005, 03:27 AM
Uber Luber
Thomas's Avatar
yeah no kiddin. At the first of the year I weighed 220lbs and now Im down to 185lbs I dont know what happened but hey, more weight loss for the car I guess
Thomas is offline
post #11 of 39 (permalink) Old 08-26-2005, 03:38 AM
seawalkersee's Avatar
I used to be hard on the trail for one of those aluminum ones. Then I started seeing the way that the cover flexes and thought...I would be willing to bet if you have 400 hp and sticky tires that you will crack the aluminum one. Now, I will be happy with the cast one and make the cover brace.
Chris
seawalkersee is offline
post #12 of 39 (permalink) Old 08-26-2005, 03:51 AM
Uber Luber
Thomas's Avatar
the aluminum case should really have no reason to crack, the cover would be the only problem, which can be solved with the conver brace and poly mount bushings. I also invested in the poly bushings, cover brace, and the reinforced rear mount, along with the pinion brace, which all combined, should make the differential virtually indestructible.
Thomas is offline
post #13 of 39 (permalink) Old 08-26-2005, 10:22 PM
When I weighed my FRPP 3.73 rearend it came in at around 80 lbs.
Trac-lok adds to weight possibly?
r
Most fun I ever had was with the Texas TCCOA guys making power and drag racing.
Now I am using a 2001 BMW M3 Vert for fun.
RichardM is offline
post #14 of 39 (permalink) Old 08-26-2005, 10:55 PM
I agree with that. When I broke the cover on my FRPP centersection (aluminum case, 3.73's, and T-Loc), no damage at all occured to the case. The chances of breaking the case itself are pretty slim, the cover and halfshafts are usually the weak links.
Definitely. Thomas, were both of the diffs that you weighed equipped (or not equipped) with a Trac-Loc?
-Rod
post #15 of 39 (permalink) Old 08-27-2005, 12:11 AM
Uber Luber
Thomas's Avatar
-Rod
Both are open diffs. well at least I was told...by you Remember the 8.8 you sold me? You told your dad it was an open 3.08, so Id assume thats what it is. Cast iron is naturally much heavier than aluminum, so 20lbs seems about right for the same internals.
Thomas is offline
post #16 of 39 (permalink) Old 09-06-2005, 08:56 PM
Rude's Avatar
Send a message via AIM to Rude Send a message via Skype™ to Rude
Go to a junk yard and get the pumpkin out of a Lincoln Mark VIII. It's aluminum and limited slip. But I put a Auburn Pro in mine.
Rude
Rude is offline
post #17 of 39 (permalink) Old 09-06-2005, 09:18 PM
Boom.
Palmguy's Avatar
Rude
All Mark VIIIs have traction control, which means none of them have limited slip. Still a good pumpkin though...if you put a TL in it yourself.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #18 of 39 (permalink) Old 09-24-2005, 12:28 PM
The lighter weight is significant. It's unsprung weight. I'd ditch the iron pumpkin.
ND4SPDLSC is offline
post #19 of 39 (permalink) Old 09-24-2005, 12:34 PM
Traveler's Avatar
Not necessarily true. I purchased a Trac-Loc pumpkin out of a SuperCoupe and it has 3.27 gears, which is what I wanted.
I would love to have an aluminum case, but don't want to pay anyone to swap internals from my cast Iron case. And its a little higher on the mechanics scale of difficulty than I am currently at right now.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #20 of 39 (permalink) Old 09-24-2005, 01:21 PM
The Great Obucina's Avatar
reduce your sig to ten lines please.
"Booyah". Stu Scott.
The Great Obucina is offline
post #21 of 39 (permalink) Old 09-24-2005, 01:35 PM
Teeps's Avatar
I hate iron pumpkins with the flaky rust... drives me nutz, the carrier is equally as heavy in either case
I prefer the AL.
1997 Sport - Work in progress:>
MP BB 304 Teksid 4v- w IC'd / Ported M112
Need:
Eaton pulley puller (VMP or BF preferred)
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #22 of 39 (permalink) Old 09-24-2005, 01:59 PM
How do you figure that it's unsprung weight? (It isn't).
-Rod
post #23 of 39 (permalink) Old 09-24-2005, 05:30 PM
I was going to ask that too. Unsprung weight is weight that is directly effected by the forces of the road vs the car. Wheels, tires, brakes, Controll arms etc. The pumpkin is sprung weight that is controlled by the springs. Make sence?
Chris
post #24 of 39 (permalink) Old 09-25-2005, 12:26 AM
Chapter Director Coordinator
jamesD's Avatar
no kiddin.. i moved the pumpkin w/ some fluid in it by the mount holes with my thumbs
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #25 of 39 (permalink) Old 10-27-2009, 09:16 AM
CometGSR's Avatar
An old bump for a good thread.. So, to make it clear to me, the Mark VIII pumpkin is a bolt on with no modification. I plan on getting trac-lock, 3.73s mounted into the Mark pumpkin. I just want to make sure mounting won't be an issue.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #26 of 39 (permalink) Old 10-27-2009, 10:02 AM
Buckcreekbilly's Avatar
At least it's weight at the rear, can't hurt traction.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #27 of 39 (permalink) Old 10-27-2009, 06:58 PM
Correct. It is a direct bolt in.
post #28 of 39 (permalink) Old 10-28-2009, 07:02 AM
since this old thread has been revivied, perhaps I could ask a few questions and become a little more educated.
what does the 96 cougar 4.6 come with? what gearing I mean, and what would adding the MKVIII rear end do for me. what differences would I notice with changed gear sizes and trac-loc?
BigJohnny is offline
post #29 of 39 (permalink) Old 10-28-2009, 07:13 AM
CometGSR's Avatar
Thanks guys!
The 1996 Cougar has 3.27 gears and may or may not have Trac Loc. You can change the gears like I am doing (I have 3.08, going to 3.73) and add Trac Loc to do a little better off the line. Most people get Mark VIII 1993 one piece driveshafts and a SCT Tune after. You don't really add a "Mark VIII rear end" to your Cougar, just some componets from the Mark. I didn't know much about this until I started a few threads and did some searching.
I think I might stay with the iron pumpkin to get a little more weight on the rear wheels for better traction.
-=James
CometGSR is offline
post #30 of 39 (permalink) Old 10-28-2009, 07:30 AM
think about this for those who want a little more weight on the rear.....just add 2 gallons of gas to the car....damn near the same weight.
