steering wheel moves to left under light braking - TCCoA Forums
post #1 of 7 (permalink) Old 09-05-2005, 02:05 PM Thread Starter
Hi, I have a 97 t'bird sport with 62k miles on rough michigan roads. My steering wheel pulls gently to the left with just the slightest brake pedal application. I have new tires, rotors, pads, and calipers. The brakes seems to stop the car allright. but a slight stap of the brakes at high speed will result in the same slight pull to the left. Any help woulb be appriciated. Thanks
rdensel is offline
post #2 of 7 (permalink) Old 09-05-2005, 07:56 PM
cbasstb95's Avatar
Send a message via MSN to cbasstb95 Send a message via Yahoo to cbasstb95 Send a message via Skype™ to cbasstb95
Alignment is the first place I would look
Audio System
Sony Mobile ES CDX-C90
Sony XDP-4000X Digital Preamp
4 Kicker 6 1/2" RS6
4 Kicker 1" RS6 Tweeters
2 Kicker K69
4 Sony XS1090 P5
2 Sony XM-DS16000P5
5 Sony XM-2800
Sony Mobile ES 6 Disk CD changer
Sony XA300
IXOS power and ground wiring
IXOS GAMMA rca's
Tsunami distribution blocks
Optima Red Top
2,400 Watts RMS
OK so I may not know engines but I can pimp the hell out of your audio system.
cbasstb95 is offline
post #3 of 7 (permalink) Old 09-05-2005, 09:29 PM
well if its like me... its the brake grabs harder on that side... I know thats my prob cuz the tire is harder to spin on my passenger side than my driver when I have the front end up in the air so I know the passenger side is already rubbin harder than driver... I don't care at the moment cuz come in another year I'll have a nice set of Cobra R's and some 13inch rotors
FunktasticLucky is offline
post #4 of 7 (permalink) Old 09-05-2005, 10:52 PM
A tip mentioned in the haynes manual is that you have contaminated one of you brake pads with grease (from the outer tie rods). And check the insulator bushings on the calipers. Hmmmm, what else; I think I read a post where someone noticed the strut rod was loose and it was doing this. And if you get desparate, swap rotors and see if the problem switches(pulls to the right instead). Hope this helps.
Perch
perch is offline
post #5 of 7 (permalink) Old 09-06-2005, 11:23 AM Thread Starter
Thanks for the responces
YOu have given me places to look. I DO think you side is harder to turn than the other. Also swapping rotor side to side is a great idea too. Hopefully I will report back with answers. Rhanks again.
rdensel is offline
post #6 of 7 (permalink) Old 09-06-2005, 09:56 PM
Check the lower ball joints.
Mad1stGen is offline
post #7 of 7 (permalink) Old 09-07-2005, 07:20 PM
My driver's side lower ball joint was worn and damaged. I took the opportunity to replace upper and lower control arms, upgraded shocks and springs to "Sport", got an alignment and the problem is gone.
I come from a dusty place.
4point6r0x0rz is offline
