Suspension Problem - TCCoA Forums
post #1 of 4 (permalink) Old 09-13-2006, 08:00 PM Thread Starter
Suspension Problem
Alright, I'm not very technical with the terms or parts... But was wondering if you could help me out here...
I've been noticing a clunking sound comming from the underbody, I've been trying to ignore it for a few weeks, because I haven't been able to afford to fix it.
I looked underneath, and the part that is broken, seems to be a little rod that connects underneath to a part underneath a big coil in my suspension, next to my right back tire. I apologize, I cant be more specific, but I'm sure you can picture it. The rod is clear off the part, and that side sags a little bit. Will I damage anything if I drive it like that for a little while longer, and how much do you suppose it would cost to fix?
thanks.
stevethecanadian is offline
post #2 of 4 (permalink) Old 09-13-2006, 08:04 PM
Baby Huey
warmaster259's Avatar
Swaybar endlink?
Jim
warmaster259 is offline
post #3 of 4 (permalink) Old 09-14-2006, 09:02 AM
I had the same problem. My sway bar end link bushing fell out and this caused the end link to bang against the sway bar. I caught the problem early and fixed it. I am sure over time the end link would have broken without the rubber busing in place. I would guess that the noise that you hear is the same. It is an easy fix once you find the replacement rubber bushing.
W.Cup is offline
post #4 of 4 (permalink) Old 09-14-2006, 02:15 PM
Baby Huey
mine did break the endlink thats why i asked.
Jim
