Isolator issues - TCCoA Forums
post #1 of 9 (permalink) Old 09-14-2006, 04:11 PM Thread Starter
Isolator issues
I tried lowering my bird using an eibach pro kit... now the rear was supposed to be lowered 1.5" I got poly isolators for the rear from supercoupeperformance.com and with them it actually raised .5" off stock... can anyone tell me the thickness of the stock isolators or tell where to get the right ones?
Jersey Bird is offline
post #2 of 9 (permalink) Old 09-14-2006, 04:32 PM
LOLA's Avatar
The new springs need time to settle.
Remeber you are replacing close to 10 year old springs as well as the isolators.
Also the new springs are stiffer than the stock ones you replaced.
LOLA is offline
post #3 of 9 (permalink) Old 09-14-2006, 04:37 PM
Mark M. TCCoA VP's Avatar
Give it two weeks and all will be well.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #4 of 9 (permalink) Old 09-14-2006, 04:48 PM
see, thats funny, when I installed my 1.5's, they were low right away....weird, every car is indeed different.
post #5 of 9 (permalink) Old 09-14-2006, 05:12 PM Thread Starter
You guys sure... I mean these isolators I got were damn huge and plus my '96 bird only has 25k on it. A 2" difference from where it should be is alot.
post #6 of 9 (permalink) Old 09-14-2006, 06:14 PM
tbird462002's Avatar
Did you change your sway bar endlinks
2.25 Mid-mount true dual exhaust,
K&N cone , 22c plugs , Magnecor 8.5 wires, Addco 1 3/8 swaybar, XCal 2 , 02 Gt maf,Vogtland Springs, Sport Fronts-Cobra Rears,RSTB, Auburn Pro w/3.73s, Steeda IRS Brace
tbird462002 is offline
post #7 of 9 (permalink) Old 09-14-2006, 06:41 PM Thread Starter
um... at the risk of sounding like a de de dee... i thought only the front had a swar bar... but anyway, no
post #8 of 9 (permalink) Old 09-14-2006, 06:53 PM
not necassary...I didn't change my endlinks.
If I were you, I'd pull the new Isolators, and put your stock ones back in.
Hell, I don't even run em anymore....not noisy what so ever.
post #9 of 9 (permalink) Old 09-17-2006, 11:26 PM
Send a message via AIM to thc70
when i installed the -1.5 pro kit with the poly islolators i had the same issue. the car was jacked up looking in the rear. i put about 5k on the car over the last year and there just starting to even out. i think my stock springs were saggin 1.5 inches so i didnt see a big differance in height. so i would leave the poly isolators and you will be fine.
1995 thunderbird lx
thc70 is offline
