Rattling sound when going over bumps - TCCoA Forums
post #1 of 4 (permalink) Old 09-14-2006, 07:39 PM Thread Starter
I just noticed a rattling sound the other day coming from the rear end, especially when I go over bumps.
Now, it doesn't happen over just any bumps. It mainly happens when I'm on a rock driveway, slowly, or when I happen to go over pavement that sections had been replaced. (The 'lines' in the road.)
Not sure what it is. I've checked almost everything, and made sure everything was tight. It almost sounds like a slapping sound.
95XR7 is offline
post #2 of 4 (permalink) Old 09-14-2006, 09:39 PM
Check your rear stabilizer bar link kits.They become worn and you really can not see the play , but the ball joint end gets lose and in smooth conditions the stabilizer bar takes up the slack,and when you go over uneven area,s the bar springs and the ball joint clunks.Hope this helps,regards Jim
park7163 is offline
post #3 of 4 (permalink) Old 09-16-2006, 06:44 PM
Sounds like a good guess. Mine fell out on the drivers side. I happened to be replacing the shocks and cut down the old rubber bushing from the old shock and presto - no more problem.
Plankster is offline
post #4 of 4 (permalink) Old 09-22-2006, 02:51 AM Thread Starter
Found out what the noise was.
The noise happened to be my brake pads. The anti rattle clip on the outside pads seemed to have come off.
Atleast, I noticed I should probably replace my shocks soon.
95XR7 is offline
