hub swap questions - TCCoA Forums
post #1 of 4 (permalink) Old 10-10-2006, 03:51 PM Thread Starter
thewishkah's Avatar
Send a message via AIM to thewishkah
hub swap questions
Last night I was looking up new wheel bearings and I found complete hubs, I would like to open up the oportunity for more wheel choices by using the mustang hubs. My questions is what is all required for the hub swap? because from what the hubs look like it looks kind of simple and I am not used to things being that easy so I figure there is more to it then what i see.
Any thoughts, comments, guidence, or a write up would be GREATLY apreciated.
thewishkah is offline
post #2 of 4 (permalink) Old 10-10-2006, 04:02 PM
girdnerg's Avatar
There's a write-up in the tech article section off the main page. It's under suspension and is for changing from the MN-12 to SN-95 bolt pattern.
Second from bottom.
Can't help with any first-hand experience, since I only did the t-bird drum to disc swap with the PBR's up front.
Rob
girdnerg is offline
post #3 of 4 (permalink) Old 10-10-2006, 04:32 PM Thread Starter
thewishkah's Avatar
thanks that is as easy as I thought Yippie! lmao I guess this will be happening soon since I need new bearings anyway.
post #4 of 4 (permalink) Old 10-11-2006, 07:00 AM
Moved to Suspension.
