Suspension Overview / Rebuild - TCCoA Forums
post #1 of 16 (permalink) Old 10-24-2006, 11:20 AM Thread Starter
I read the stickey " what to check if you suspension is clunking" .
My 97 t-bird with 95k miles on it is due for a front end rebuild. I've replaced both front sway bar links and I think that one of them is going out again due to a crummy replacement part.
Has anyone come up with a list of things to replace, costs, and best part and place to purchase them from? I'd hate to miss some $20 part and still have problems or purchase another crummy aftermarket part just to have it fail in 10k miles again!
Seems like some aftermarket parts are better than others and some parts need to be replaced with the ford parts?
Also does anyone know the correct torque settings for the front end? Maybe a chilton or hayes manual would have these?
Is it common for the boots on the uca's to "rot" away?
Thanks for any and all help!
97TXBIRD is offline
post #2 of 16 (permalink) Old 10-24-2006, 12:28 PM
wether's Avatar
The torque specs can be gotten off of the CD manuals that can be downloaded from http://www.fordcds.com .
The only part I am sure that the ford part should be used is the strut bushings (they are on the lower control arm just inside the ball joint) and TRW lower control arms. I just rebuilt the front end on one of my t-birds and used some nice FRPP upper control arms that Jason got for me for the same price as aftermarket. . . .To say the least, I was impressed. Contact Jason at the FordPartsCounter thread.
Just my thoughts. . . . .going away now.
wether is offline
post #3 of 16 (permalink) Old 10-26-2006, 04:18 PM Thread Starter
I can't find the FordParthCounter thread what subfolder is it in?
97TXBIRD is offline
post #4 of 16 (permalink) Old 10-26-2006, 04:21 PM
wether's Avatar
http://forums.tccoa.com/index.php under "Marketplace"
wether is offline
post #5 of 16 (permalink) Old 10-26-2006, 08:44 PM
Where in Houston are you? There's a good group of T-Bird owners in town; I'm sure we can help you out if you need it.
It's only funny until someone gets hurt.
Then it's freaking hilarious.
Adventures in ChumpCar Racing
Tobey is offline
post #6 of 16 (permalink) Old 10-26-2006, 10:21 PM
Ford Parts Counter
post #7 of 16 (permalink) Old 10-30-2006, 03:23 PM Thread Starter
Tobey,
I'm in North Houston near Humble/Kingwood.
I think I'll be able to handle it just want to make sure I replace everything that needs replacing and don't leave out some little part.
Also,
I plan on doing the front end one weekend and the rear on another time. Can I get just a 2 wheel alignment done or do I have to get a 4 wheel alignment both times$$$
THX
97TXBIRD is offline
post #8 of 16 (permalink) Old 10-30-2006, 08:47 PM
Tobey,
Also,
THX
Just go somewhere like Firestone and get the lifetime alignment.
Tobey is offline
post #9 of 16 (permalink) Old 10-31-2006, 09:50 AM
Traveler's Avatar
Ok, I'm going to add to this thread instead of making a new one.
I'm going to be replacing my upper control arms soon, and wanted to know something about the procedure. Is it difficult, dangerous, etc.? I've replaced the springs in the car already, so once the spring/shocks are out, what is involved in getting the old UCA's out and the new ones in?
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 16 (permalink) Old 10-31-2006, 09:55 AM
bad93bird's Avatar
You still have to drop the spring/strut assembly. The only hard part about the UCA is the nuts near the firewall. Some can be a *****. I've done my whole front suspension. I need to do the rear. It is just more expensive.
I've got a question. Where do I get the bushing for the strut rod? I need the one inside near the sway bar.
QUADSQUAD MEMBER
bad93bird is offline
post #11 of 16 (permalink) Old 10-31-2006, 09:57 AM
Traveler's Avatar
LOL man, I'd better go take a good look at my front suspension. You guys are talking about parts I'm not familiar with (well, unless I'm looking at the front end at the time).
And I can safely assume that a front end alignment is required following the replacement of the UCA's?
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #12 of 16 (permalink) Old 10-31-2006, 10:01 AM Thread Starter
Travler I found this guys site for doing the uca's great instructions
http://planet.tvi.edu/bpearce/1994Mercury/UCA/index.htm
Does firestone do the spring / strut changeover ie have a wall mounted spring compressor so I don't lose an eye?
Are there any parts at the top of the spring/strut assembly that need to be replaced?
97TXBIRD is offline
post #13 of 16 (permalink) Old 10-31-2006, 10:03 AM
bad93bird's Avatar
I would. You will be removing the strut/spring assembly. So some thing may be not correct when put back together. I believe I'm right about the strut coming out.
QUADSQUAD MEMBER
post #14 of 16 (permalink) Old 10-31-2006, 01:33 PM
Most definitely you'll need an alignment afterwards.
As far as the strut rod bushing, I've read that the only one worth getting is the Ford one.
post #15 of 16 (permalink) Old 10-31-2006, 02:49 PM
I'm sure they do. No idea what they might charge, but it's worth it.
The top of the spring sits against a big rubber piece. MONROE Part # 901970 on www.rockauto.com . $28 each. Might as well replace it while it's out...
Tobey is offline
post #16 of 16 (permalink) Old 11-01-2006, 11:20 AM
bad93bird's Avatar
I thought there was one out there that was better than the Stealership.
QUADSQUAD MEMBER
