heaviest duty shocks front/rear, achieving SC-handling. - TCCoA Forums
post #1 of 2 (permalink) Old 11-10-2006, 03:05 AM Thread Starter
The_Ghost's Avatar
What are the stiffest, most heavy-duty shocks avail for the LX and who makes them?
I want the LX I'm buying to handle as well as my SC did with its tired, worn out ARC system.
There are lots of dips in my neighborhood and I want to keep the nose of the car stable and minimize brake-dive.
It looks like the recommendation is Motorcraft 96 Sport valved front shocks and 99-04 Cobra Conv't. rears? Do the cobra convertible rear shocks bolt up like stock?
Second, am I able to use SC springs front/rear, or would I be better off simply replacing the springs? I do not want to lower the car, but simply firm up the ride and keep the car from bottoming out.
How different is the SC's front sway bar from the LX and should I go to the trouble of obtaining and installing an SC front sway bar?
Ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #2 of 2 (permalink) Old 11-10-2006, 09:32 AM
fast Ed's Avatar
Koni manually adjustable shocks. You can set them stiffer than you'll ever need for the street.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
