strut rod bushing install question, big bushing on front right? - TCCoA Forums
post #1 of 2 (permalink) Old 11-15-2006, 11:48 AM Thread Starter
ThunderB's Avatar
I had the Ford bushings installed when I had the front end of my car rebuilt a few weeks ago. O work at a tech school, so I let the autoshop do a project on my car. I finally got under it Saturday to check things out and it looks like they reversed my cross member strut rod bushings.
how are the bushing to be installed? The large bushing is the front and the small one is the rear bushing isn't it? It looks like they put the small bushing on the front and the larger one on the rear of the cross member.
I checked the box from Ford and there weren't any instructions in it.
97 T-Bird Sport: Dynomax catback, Removed silencer w/ K&N panel, DReinhart chip, Lightning AGSF12-FM1 plugs/180 stat, Tokico 1.25" dropped stance, bye bye fender gap
'79 F100 SB : 300 ci six, Hurst Mastershift 3spd floor shifter, Offenhauser intake, Holley 4 brrl, EFI manifolds, Chebbie Rockers, Summit Racing 3.50 gearset, DISO 2.5" diesel muffler and 2.5" exhaust, Its'a six?!
ThunderB is offline
post #2 of 2 (permalink) Old 11-15-2006, 02:28 PM Thread Starter
ThunderB's Avatar
I checked Mitchell OnDemand and answered my own question. Bushing with the metal flange goes in front, bushing without the metal flange goes behind the crossmember. The bushings are labeled FRONT and REAR to remove any doubt.
The front washer faces front and the rear washer faces rear, just the opposite of what you'd think.
They also recommend tightening the lower shock bolt with full weight on the suspension to prevent binding or wrapping of the shock bushing. Of course, we already knew this, but for those who don't...there it is.
ThunderB is offline
