Clunk! - TCCoA Forums
post #1 of 9 (permalink) Old 11-16-2006, 05:47 PM Thread Starter
Clunk!
I recently went through and replaced a lot of the bushings in the front of the car. Ever since then, I get a small "clunk" when I go over bumps. It only happens when I'm driving on a really bumpy road or hit a pothole or something like that. If I'm on a relatively smooth highway, I hear nothing. It almost sounds like its at the upper shock mounts but they're tight. I've also been under the car and double checked and re-tightened everything but found nothing obvious or unusual. Does anybody have any suggestions?
fold_em83 is offline
post #2 of 9 (permalink) Old 11-16-2006, 07:48 PM
JustinH's Avatar
lower balljoints..
JustinH is offline
post #3 of 9 (permalink) Old 11-16-2006, 09:56 PM
CEO, WT Club
GODSPEED's Avatar
Does it kinda sound like a pop-can being crushed when you go over railroad tracks?
-Joel
Previous MN12s:
GODSPEED is offline
post #4 of 9 (permalink) Old 11-17-2006, 06:30 AM Thread Starter
Lower ball joints are new. So are the upper ones. No, it doesn't sound like a pop can. It just makes a clunk. It sound like the upper shock mounts are loose but they're not.
post #5 of 9 (permalink) Old 11-17-2006, 07:18 AM
I had a similar clunking noise that I couldn't pinpoint. I'd replaced the upper control arms, but some of those nuts inside the engine compartment were a pain to reach, and I must not have torqued them tight enough the first time. I put a wrench on the nuts and used my torque wrench on the bolt head and was surprised by how loose they were. The second time I must have gotten it right, because that took care of the noise and it hasn't come back in a year.
Black 94 SC
Black 95 SC
Black94SC is offline
post #6 of 9 (permalink) Old 11-17-2006, 08:11 AM
nickleman60's Avatar
check your stabilizer links on the sway bar.
94 SC AUTO - $$$$ Pit
nickleman60 is offline
post #7 of 9 (permalink) Old 11-17-2006, 09:38 PM Thread Starter
I'll double check the upper control arm bolts. Thats one that I forgot to check again. Upper and lower control arms are all new. Sway bar links are new too. The only thing I didn't replace was the plate at the top of the spring/shock assembly. Could this be my problem?
post #8 of 9 (permalink) Old 11-25-2006, 09:53 PM Thread Starter
I'd like to thank Black94SC for the good call on the upper control arm mounts. I just ran them down w/ an air ratchet and that apparently wasn't good enough because they were loose. Tightened them up with a wrench and shes quiet as can be.
post #9 of 9 (permalink) Old 11-26-2006, 06:28 PM
blkadder's Avatar
I had the same issue on my 94 after the uppers were replaced. It went back to the shop twice for the noise, and they couldn't find it. I went in there with a wrench and a ratchet, and got about 1/4 of a turn out of the left side nuts. Since then, no noise.
Ron
...Semper Fidelis...
blkadder is offline
