rear sway bars. - TCCoA Forums
post #1 of 17 (permalink) Old 11-20-2006, 09:37 PM Thread Starter
TwoHaggard's Avatar
rear sway bars.
hey. i wanna do a rear sway bar. so if i go with the 1 1/4 i dont have to change the frount one right? at a later date ill prolly do the frount. just want a lil better handleing. do u think the Addco 1 1/4 is a good choice. i just wanna hear what u guys think n learned from doing it yourselfs.
thx dank.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 17 (permalink) Old 11-20-2006, 09:51 PM
Who is John Galt?
Originally Posted by TwoHaggard
so if i go with the 1 1/4 i don't have to change the front one right?
Correct
do you think the Addco 1 1/4 is a good choice.
Unless you're replacing it with a factory bar, I'm pretty sure that Addco is the only name in the game. My plans are for 1 1/4" bars front and rear eventually. I did buy a 91 SC bar for the front, but it was too much of a PITA to install it at the time.
BTW - Spelling words correctly is a good thing
"Won't work, can't be done"
cougar_guy04 is offline
post #3 of 17 (permalink) Old 11-20-2006, 10:09 PM
Traveler's Avatar
I've got (or had) a set of 89 SC bars on my 97 Bird. They are pretty good for the price. Just a whistle smaller than the SC bars. 1.10" in rear and 1.20" in front. I paid 100 dollars for the set used.
And Cougar_guy04 is correct the front one is a pain to install, (and spelling does count)
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 17 (permalink) Old 11-29-2006, 02:23 PM
the other guys
Got my bars from PST.com. Excellent quality, better price, nice folks.
Sharon Silver is offline
post #5 of 17 (permalink) Old 11-29-2006, 04:47 PM Thread Starter
TwoHaggard's Avatar
pst?
post #6 of 17 (permalink) Old 11-29-2006, 06:43 PM
cougarnut281 is offline
post #7 of 17 (permalink) Old 11-29-2006, 07:45 PM Thread Starter
TwoHaggard's Avatar
1 1/4 make more oversteer or understeer?
post #8 of 17 (permalink) Old 12-02-2006, 08:25 AM Thread Starter
TwoHaggard's Avatar
any1 know..
post #9 of 17 (permalink) Old 12-02-2006, 08:35 AM
Mark M. TCCoA VP's Avatar
The 1 1/4" rear bar with the stock front bars moves you away from understeer to a more neutral setup.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #10 of 17 (permalink) Old 12-03-2006, 02:34 PM Thread Starter
TwoHaggard's Avatar
accelerating out of a turn. would make slide back end around more or what?
post #11 of 17 (permalink) Old 12-03-2006, 02:37 PM
You can read all about it in the tech articles section of this site.
Oversteer
Oversteer is when the rear wheels are carving a larger arc than the front wheels or the intended line of the turn. Rear "slip angles" exceed those of the front tires. This is often described as a "loose" condition, as the car feels like it may swap ends, or be "twitchy."
This condition can be caused by "power oversteer", where you need to reduce power in order to bring the back end back into line.
Understeer
Understeer is when the front wheels are carving a larger arc than the rear wheels. This is often described as "push" or "pushing" - as the front end feels like it is plowing off of a corner.
Further acceleration only compounds the push, as weight shifts back to the rear drive wheels off of the front turning wheels, leading to a further lessening of the car's ability to turn in.
Understeer can be remedied by slight modulation in throttle to transfer weight forward to the front wheels, aiding their traction and ability to carve the turn.
Many cars are designed to have a tendency to understeer. If the driver gets uncomfortable and "lifts" off the gas, that will cause the front end to tighten the curve - a relatively safer, and more predictable condition for the common driver.
post #12 of 17 (permalink) Old 12-03-2006, 04:21 PM Thread Starter
TwoHaggard's Avatar
so the 1 1/4 bar would prolly be the best for handleing. n kickin it sideways if i wanted to..im not fast n furious im just askin?
post #13 of 17 (permalink) Old 12-04-2006, 08:51 PM Thread Starter
TwoHaggard's Avatar
so i guess im going to get the 1 1/4 rear sway bar. should i order anything else while im at it..
Short Rear Sway Bar Link Kit - with Polyurethane Bushings ?
any other bushings or anything?
post #14 of 17 (permalink) Old 12-04-2006, 09:19 PM
Where on this site, or p-s-t.com, are there MN12 sway bars?
mercutio is offline
post #15 of 17 (permalink) Old 12-04-2006, 09:38 PM
Traveler's Avatar
You'll only need the short sway bar link kit if the car has been lowered.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #16 of 17 (permalink) Old 12-04-2006, 09:50 PM Thread Starter
TwoHaggard's Avatar
ya its lowerd 2in with intrax
post #17 of 17 (permalink) Old 12-06-2006, 10:06 PM Thread Starter
TwoHaggard's Avatar
so u think that is all i need and or should get?
