Drum rear to disk conversion? - TCCoA Forums
post #1 of 6 (permalink) Old 11-25-2006, 08:42 PM Thread Starter
Hi gang,
Got a buyer that wants the entire independent rear suspension and gears to put into a street rod. His question is if he buys it is "can he change the drum brake system to disk. Any special considerations? Can he use everything else as is and just change the brakes to disk? Thanks for any input you have.
PS. What would you folks consider a fair price for the rear set up??
PSS. My cars are all non SC cars from 89 to 94.
BunchaTBirds is offline
post #2 of 6 (permalink) Old 11-25-2006, 10:35 PM
I know it is possible, but I'm not sure exactly what needs to be changed. He might need to buy different spindles, or maybe its just a different bracket to mount the calipers instead of the backing plate from the drum setup. Also the brake lines and the parking brake cables will be different.
Mike
post #3 of 6 (permalink) Old 11-26-2006, 06:30 PM
blkadder's Avatar
Check the tech articles. There is everything you ever wanted to know on how to change to rear disks.
Ron
...Semper Fidelis...
blkadder is offline
post #4 of 6 (permalink) Old 11-26-2006, 06:58 PM
coggonobrien's Avatar
u get new knuckles off a disc bird. then the calipers/rotors/brackets. if he were to use tbird front brakes he would want the proportioning valve also
coggonobrien is offline
post #5 of 6 (permalink) Old 11-27-2006, 09:07 PM Thread Starter
Thanks all, for the info.
post #6 of 6 (permalink) Old 11-28-2006, 12:51 AM
Don't forget about the brake cables and hoses for the calipers.
