Suspension Rebuild/Upgrade Parts - TCCoA Forums
post #1 of 8 (permalink) Old 01-03-2007, 02:38 PM Thread Starter
I need some help compiling a parts list for the suspension rebuild on my 94. I want to make sure I'm not missing anything.
upgrades I already have (or am about to buy)
-Eibach 1.5 drop springs
-KYB GR2 shocks
-Addco front/rear sway bar 1&1/4
and this list I found by searching, its somewhat old so I want to make sure everything is included? Most of the parts are moog... are there any parts that I am missing or should be motorcraft instead?
Upper Control Arm
LEFT - INCL BALL JOINT K8596
RIGHT - INCL BALL JOINT K8598
Cam & Bolt Kit K8521 x2
Lower Control Arm
LEFT - INCL BALL JOINT K80053
RIGHT - INCL BALL JOINT K80055
Strut Rod Bushing/Kit MOTORCRAFT Frame Side
Strut Rod Bushing/Kit MOTORCRAFT LCA Side
Tie Rod End Link ES3004RL x2
Rear Suspension
*REAR COMPENSATOR LINK K8594 x2
*Sway Bar Link/Kit K8641 x2
*Upper Control ARM TO FRAME K8562 x2
*Upper Control Arm ARM TO KNUCKLE K8588 x2
*Lower Control Arm Kit ** * K8658 x2
slo1 is offline
post #2 of 8 (permalink) Old 01-03-2007, 02:47 PM
Do not use moog strut rod bushings, the ford parts are about the same price and considerably higher quality. I would add some front shock mounts and you are likely to need lower shock bolts as well.
post #3 of 8 (permalink) Old 01-03-2007, 02:48 PM
Might want to consider new sway bar links as well. These are the things I went wrong on on my build and had to do it over.
post #4 of 8 (permalink) Old 01-03-2007, 02:50 PM Thread Starter
Wont the addco kits come with new bushings?
slo1 is offline
post #5 of 8 (permalink) Old 01-03-2007, 02:53 PM
strut rod?
The sway bar links are not part of the bar, mine are bad and rattle like crazy, the addco will not have the links. The frame bushings may be supplied however.
post #6 of 8 (permalink) Old 01-04-2007, 12:18 AM Thread Starter
Originally Posted by dirtyd0g
strut rod?
?? Yeah, I'm clueless... which is why I've been glazing over all the old threads to try and find a definitive list (a sticky would be awesome). I have never worked on suspension before and I plan on probably having the rebuild work done by a pro. I just want to get all the facts straight and the parts bought before I sacrifice my wallet.
slo1 is offline
post #7 of 8 (permalink) Old 01-04-2007, 02:30 AM
The strut rod is not the sway bar.
post #8 of 8 (permalink) Old 01-04-2007, 10:07 AM Thread Starter
Ok, so does the rest of the list look complete? Anything else to add?
slo1 is offline
