Tubular LCA's..are these real??? - TCCoA Forums
post #1 of 14 (permalink) Old 01-14-2007, 04:31 PM Thread Starter
It's not what's getting sold but if you look at the other picture you'll see them.. They look too dinky to be functional. They're probably mock up's..
http://cgi.ebay.com/ebaymotors/ws/eB...3887%26fvi%3D1
Justin McC
Stinkfist04 is offline
post #2 of 14 (permalink) Old 01-14-2007, 08:07 PM
96bird's Avatar
That is a bracket to be able to run Cobra rear rotors (tbird calipers) on an MN-12.
Russell
96bird is offline
post #3 of 14 (permalink) Old 01-14-2007, 08:19 PM
Traveler's Avatar
The MN12/FN10 Independent rear suspension is real popular with the folks building Coba Replicas. That is what is pictured in the Ebay Ad.
And has been stated, the brackets being sold in the ad are for adapting the larger Cobra rear rotors to the MN12.
Be grateful for this market. It has provided us with some parts that otherwise wouldn't be built.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 14 (permalink) Old 01-14-2007, 09:26 PM Thread Starter
I know about the bracket.. What I was pointing out was the Tubular Lower Control Arms in the 2nd picture not the bracket. That's why I said "It's not whats getting sold". Are those Lower Control Arms an aftermarket production piece or just a mock up? I was intreaged by them.
Justin McC
post #5 of 14 (permalink) Old 01-14-2007, 09:29 PM Thread Starter
Here's the pic
Justin McC
post #6 of 14 (permalink) Old 01-14-2007, 09:29 PM
Traveler's Avatar
Originally Posted by Traveler
The MN12/FN10 Independent rear suspension is real popular with the folks building Coba Replicas. That is what is pictured in the Ebay Ad......
The tubular a arms is what I was referring to. I don't know if they'll fit an MN12 or not. You might do a search among the Kit Cobra websites and forums and be able to find out however.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #7 of 14 (permalink) Old 01-14-2007, 10:09 PM
96bird's Avatar
Those are for the Cobra kit car....sorry I should have read the question better.
Russell
96bird is offline
post #8 of 14 (permalink) Old 01-14-2007, 10:13 PM Thread Starter
I wonder if they have the same dimensions of ours. and if so.. I wonder how much they cost. I bet if one beefed them up with gussets and such they'd be alright. Of course something would have to be done about a spring pocket.
Justin McC
post #9 of 14 (permalink) Old 01-14-2007, 11:26 PM
96bird's Avatar
Different length....that is why they designed a new upper/lower control arm setup and swaybar setup, iirc.
Russell
96bird is offline
post #10 of 14 (permalink) Old 01-17-2007, 09:49 AM
drag-aholic
BAGGED89's Avatar
you don't want to hear this but some bagged trucks run a thjunderbird rear end in their trucks and there is a comany that makes lowers like that for a thunderbirds rear suspension. although i can't say if they are a direct replacement. they do a lot of narrowing on these trucks. I am locked out of the site with pics while here at work but can post a pic of them later if you want to see them.
1989 LX Full Air Suspension
BAGGED89 is offline
post #11 of 14 (permalink) Old 01-17-2007, 05:34 PM Thread Starter
Yeah put up a link and pics
Justin McC
post #12 of 14 (permalink) Old 01-17-2007, 09:26 PM
drag-aholic
BAGGED89's Avatar
only pics i could find - I can't say if they are the same arms ar was posted but this is what i knew of.
they are made by a shock named KUSTOMWERKS i think they are in KY. cant remember.
BAGGED89 is offline
post #13 of 14 (permalink) Old 01-17-2007, 09:28 PM
Traveler's Avatar
Where do they mount springs and/or bags to them?
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #14 of 14 (permalink) Old 01-17-2007, 10:27 PM
drag-aholic
BAGGED89's Avatar
as far as i know they put their own bag mount on them as they can put it where they need it
BAGGED89 is offline
