Need help allocating some parts - TCCoA Forums
post #1 of 7 (permalink) Old 01-22-2007, 06:18 PM Thread Starter
coggonobrien's Avatar
i'm looking for the bolt and offset bushing that will allow for adjustment of the rear toe angle. mine our froze. i will need them for both sides. I've tried every auto place in town including the ford dealership with no luck. thanks, Dave
coggonobrien is offline
post #2 of 7 (permalink) Old 01-22-2007, 07:49 PM Thread Starter
bumpity
post #3 of 7 (permalink) Old 01-22-2007, 07:55 PM Thread Starter
if somebody has some premo one's off of a used car i would take them so long as they are in great shape
post #4 of 7 (permalink) Old 01-22-2007, 11:36 PM
jk69cat's Avatar
your ford store cant order them?
mn12 less!
jk69cat is offline
post #5 of 7 (permalink) Old 01-23-2007, 12:28 AM Thread Starter
they only have one side available, parts are obsolete
post #6 of 7 (permalink) Old 01-23-2007, 08:45 AM
jk69cat's Avatar
so your talking about the rear adjuster bolt? the front just shows a bolt that also goes thru the compensator
mn12 less!
jk69cat is offline
post #7 of 7 (permalink) Old 01-23-2007, 10:40 AM Thread Starter
yeah, it is supposed to have an offset bushing so you can slide the rear of the control arm in or out. if these are the same on each side i'd go buy two of what ford has, or i guess i could at least use the bolts for both if the bushings are differant.
