stiffer suspension - TCCoA Forums
post #1 of 21 (permalink) Old 01-27-2007, 01:18 PM Thread Starter
stiffer suspension
I have a 96 Thunderbird lx with all stock suspension and i would like for it to ride a little bit stiffer what would you recommend to get like new shocks? struts? spring? and i don't want to spend a fortune on it and any brands that you recommend would help.Thanks!
lxthunderman is offline
post #2 of 21 (permalink) Old 01-27-2007, 03:15 PM
sCrEaMiN BiRd's Avatar
For a stiffer suspension i would suggest getting a spring/shock combination. Spring's all by themselves (i have Eibach 1.5" lowering springs) did NOT stiffen the ride much more if any at all. What i suggest is to get a stiffer shock absorber. Although i do not have a "perofrmance" type shockabosorber on my tbird, on my other cars i run Tokico D Spec's (06 mustang GT) and Bilstein's (02 Lexus IS300) both stiffened up the suspension significantly. The Tokico D spec's that i have are an adjustable shock which enable's you to stiffen the ride or soften it. I'm not sure if the specific line of Tokico "Dspecs" are available for the tbird but i do know that many members use Tokico Illumina's i believe, and they are happy with them. I also run 18" wheels with a 245/45/18 tire, this also stiffens up the ride quite a bit. Good luck
sCrEaMiN BiRd is offline
post #3 of 21 (permalink) Old 01-27-2007, 11:39 PM
96bird's Avatar
A word of advice would be to get the best shocks that you can afford. I would buy the Koni shocks. If you search around a bit you can get some good info on upgrading the suspension. Just look in my sig for some ideas.
Russ
96bird is offline
post #4 of 21 (permalink) Old 01-27-2007, 11:39 PM Thread Starter
which is better kyb GR2 Gas Shocks or Gabriel ultra shocks?
post #5 of 21 (permalink) Old 01-27-2007, 11:41 PM
The Great Obucina's Avatar
neither. go koni or go home.
"Booyah". Stu Scott.
The Great Obucina is offline
post #6 of 21 (permalink) Old 01-28-2007, 01:04 AM
First thing to do is make sure nothing is worn out. Perhaps new shocks front and rear would suffice. Add braces before stiffening other things. I added homemade rear shock brace and front k-frame braces first. That alone made a huge difference. You would be suprised how much the flexi-flier chassis contributes to ride softness.
Going with all poly bushings in the rear also made a difference. I'm using a lighter hollow swaybar and the car corners alot flatter. Used one poly spring spacer and cut one coil from the stock LX springs to acheive a stock height. The harshness has increased slightly.
Sometimes on wet pavement the car actually seems TOO tight in the rear. My rear tires are worn more now but the back end will try to slide out where it hooked before. With dry roads the lack of roll makes for a controllable drift. The car actually seemed to hook better at the track with the softer stock rubber bushings.
I'm not sure about long term durability of the poly bushings. Now I'm scared to drive in foul weather because of the bushings. They are grooved to accept silicone grease. There is a possibility of dirt, salt, and water getting in those grooves. The factory rubber bushings are well made and will last a long time.
icantdrive55 is offline
post #7 of 21 (permalink) Old 01-28-2007, 10:21 AM
Now that's a biased opinion. By the way, Konis are one of the most expensive. I know there's that old saying that you get what you pay for but that's not always the case.
Another OPTION would be to run the 03/04 Cobra Bilsteins in the rear and the 96-97 Sport Shocks pn#AST-135 in the front. The Sport Shocks are the same shocks that are used on the Super Coupes.
Our cars have SHOCKS you won't need to buy any Struts.
For more information to think about see HERE, HERE, and HERE.
I recently put the Bilstein/Sport Shock setup on my car and am very pleased with it. Good Luck with whatever you decide to do.
post #8 of 21 (permalink) Old 01-28-2007, 10:25 AM
maybe because they are the ONLY shock designed and valved for performance and lowered applications. KYB are asian subcontracted crap, Tokicos soften prematurely, and I cooked a set of Ford Sport shocks with my Eibachs in just over a year. So, lower your car and replace shocks every few years or put in Konis and dont worry about it. You get what you pay for.
post #9 of 21 (permalink) Old 01-28-2007, 11:06 AM
Traveler's Avatar
No, the Sport Shocks are NOT the same as the SC shocks. The SC's had electronically controlled, adjustable shocks. The Sports just had revalved standard shocks.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 21 (permalink) Old 01-28-2007, 11:25 AM
Sorry, I misread the article. The SPRINGS are the same not the shocks.
From: http://www.tccoa.com/articles/suspension/shocks.html
Quote: "The springs of the SC bird are plenty stiff, as stiff as any aftermarket job,as they ride under all 96-7 sports, and will do a nice job over the stock ones."
post #11 of 21 (permalink) Old 01-28-2007, 11:44 AM Thread Starter
If i got sc springs would the car stay at stock driving height or would it be lower to the ground? Didnt the article say that sc springs are all around stiffer than the sports and lx.
post #12 of 21 (permalink) Old 01-28-2007, 12:25 PM
Stiffer yes. But I don't think they're any lower. Maybe someone else can confirm.
post #13 of 21 (permalink) Old 01-28-2007, 12:25 PM
Who is John Galt?
It will be the same ride height, maybe a fraction of an inch higher since you've got a base V6.
"Won't work, can't be done"
cougar_guy04 is offline
post #14 of 21 (permalink) Old 01-28-2007, 02:25 PM Thread Starter
thanks i will probably try to find a set of sc springs to stiffen up the suspension a little and maybe some shocks not koni because those things are way too expensive but thanks for the replies.
post #15 of 21 (permalink) Old 02-13-2007, 04:02 PM
hey, I work at a dealership and i just ordered a pair of rear sport shcocks and front sport shocks. No problem. and they cost 160 for all 4!
roger is offline
post #16 of 21 (permalink) Old 02-13-2007, 04:25 PM
Traveler's Avatar
You found Ford Motorcraft "Sport" front shocks? I wasn't aware they were still available. Are you certain they are sport shocks?
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #17 of 21 (permalink) Old 02-13-2007, 08:01 PM
That's what i thought. My ford parts guy said that those were no longer available?
post #18 of 21 (permalink) Old 02-14-2007, 09:40 AM
tbirdtess's Avatar
To Stiffen
Hello
To stiffen this chassis you Will Need to install spring tower braces. To get even better you will be installing better or newer Bushings.
I race this chassis on a 1/2 mile asphalt oval, Stock car, 90 t-bird. When I Xed & added a cross brace to the rear shock towers, The car changed greatly. She acted more like she was supposed too. Front spring lb. went up & rear spring lb. went down.
We are currently building a 96 T-bird to replace the 90. Going to change some of my roll bars for better stiffness(less-flex).
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #19 of 21 (permalink) Old 02-14-2007, 09:36 PM
Do you have a picture of this cross brace? I was thining about making my own or getting one from Rod. Does anyone know if Rod still makes these cross braces? Thanks
post #20 of 21 (permalink) Old 02-22-2007, 02:57 PM
Okay, scratch my last comment, they cost me $190.53, with my employee discount. yes, they are for a 96 LX with the Sport option. Luckily my Parts guy also drives a tbird. wouldn't you know it, he needed shocks for his sport and couldn't find them, til he made some calls. He got some for his car a few months ago, and he knew exactly what the number was. There are only a few left in the country, and I presume, the world?
Fronts-
3U2Z*18124*CB FOR 89.62/EA.
Rear-
F7AZ*18125*KA FOR 37.12 EA.
So $253.48 + $9.95 for freight from I think Wisconsin.
Total for y'all= $263.43
Good luck, and I really hope they will slide right in on my car!!!
-Roger
roger is offline
post #21 of 21 (permalink) Old 02-22-2007, 03:16 PM
Traveler's Avatar
Man, for less than that you can pick up a set of KYB's from Ebay. Yea, I know they aren't KONI'S but they are at least as good, if not better, than the Sport shocks.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
