better handling - TCCoA Forums
post #1 of 15 (permalink) Old 01-28-2007, 03:49 PM Thread Starter
better handling
i'm putting a 408 & c6 & 8.8 rear on my bird... what are the suspension options do i have??? it WILL be a daily driver, i do drag race, i do autocross it.....need a good all around suspension... wut should i get?
jeleighlover is offline
post #2 of 15 (permalink) Old 01-28-2007, 04:59 PM
Do you want to drop it or keep stock height? How much do you want to spend on it? The cheapest option for a drastic improvement in handling is SC or sport springs (can be had for about $80-100) and 96 tbird sport front shocks with either stock or 03 cobra convertible rear shocks. My 94 has the sport front/stock rear setup with SC springs, and I really like the way it handles.
Mike
post #3 of 15 (permalink) Old 01-28-2007, 05:24 PM
96bird's Avatar
I have some Sport springs if you want to go that route...85 shipped.
Russell
96bird is offline
post #4 of 15 (permalink) Old 01-28-2007, 09:40 PM Thread Starter
do want to lower it a bit..... got round $2g's to spend on suspension
post #5 of 15 (permalink) Old 01-28-2007, 09:49 PM
coggonobrien's Avatar
here's a radical thought if you are a do it urselfer but spend the money on a frame kit with 4 link and a shortned 9 inch with coil springs. if you can do the work urself you can save a lot of cash. here's the company i work for's website which will give you an idea on parts. Dave
http://www.quickperformance.com/
coggonobrien is offline
post #6 of 15 (permalink) Old 01-29-2007, 05:22 PM
In that case, eibach springs, bilstein shocks, addco front and rear sway bars, some 17x9 rims with some sticky tires, probably some money left over, and close to 1.0G's in the skidpad.
Mike
PS. When you do the engine swap, make sure to move the motor back in the engine bay and lower it a bit. This will also help with handling by lowering the cars center of gravity and giving the car some better weight distribution.
post #7 of 15 (permalink) Old 01-29-2007, 07:53 PM Thread Starter
thanx for the tip.... how do i lower motor??? where can i buy all these suspension parts???
post #8 of 15 (permalink) Old 01-29-2007, 08:25 PM
Who is John Galt?
Mike
I thought the Bilsteins were discontinued?
"Won't work, can't be done"
cougar_guy04 is offline
post #9 of 15 (permalink) Old 01-30-2007, 11:17 AM
Maybe they were, I don't know. I'm happy with my sport shocks, so I haven't really looked into it recently.
Mike
post #10 of 15 (permalink) Old 01-30-2007, 11:20 AM
Well the way I did it was flip the top plates to opposite sides and that will move the motor back about an inch, and then instead of using the stock mounts I drilled holes through 4 hockey pucks and put a bolt through the bottom bracket, 2 pucks, then the top plate. This way it's as strong as the bolt, but it still isolates the vibrations. Plus it only cost me $4! The other method would be to fab up some solid metal mounts but that would cost more and transfer more vibration into the passenger compartment.
Mike
post #11 of 15 (permalink) Old 01-31-2007, 04:21 PM
As far as I know, the Bilstein shocks were discontinued a couple years ago. Koni adjustables are a good option but run about $500-600 for a set.
SloMo228 is offline
post #12 of 15 (permalink) Old 01-31-2007, 06:24 PM
well he said he wants to spend $2K on suspension, so $600 for shocks isn't out of the question by those standards.
Mike
post #13 of 15 (permalink) Old 02-12-2007, 03:08 PM
PCD
Confirmed V6 Nut
I don't know if there is something that will fit the front, but in the rear you can put 03 Cobra convertible shocks (they are Bilsteins) or use rear shocks from a 97 Crown Vic from Bilstein.
PCD is offline
post #14 of 15 (permalink) Old 02-12-2007, 07:27 PM
95_SilverBird's Avatar
Originally Posted by sinhumane
so.. i couldnt find this... what do the birds pull lateral stock?.. the lx...
IIRC its a .83 or .87. Either way the LX is the same as the new v6 Mustang. IRS does make a differance.
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
post #15 of 15 (permalink) Old 02-12-2007, 07:57 PM
TwoHaggard's Avatar
http://supercoupeperformance.com/
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
