Front end noise - TCCoA Forums
post #1 of 20 (permalink) Old 02-02-2007, 11:01 AM Thread Starter
Front end noise
Over the last few weeks I have noticed a popping sound coming from the front end. This occurs when I'm backing up & turning the wheels. It will pop once & that's it. When I straighten out the wheels it doesn't happen. Also it doesn't happen all the time. I don't know if it's a coincidence or not but it seem to start when we got this unusually cold weather here in SoCal. A little over a year ago I completely rebuild the front end. New UCAs, LCAs, tie rod ends, sway bar end links, sway bar bushings, strut rod bushings. The shocks are due for replacement but I can't imagine them making that kind of noise.
Any ideas?
Bymet is offline
post #2 of 20 (permalink) Old 02-02-2007, 10:40 PM
Read all these posts and cry? Thats what Im doing and it's not helping. Only reassurance I can offer is this; YOU ARE NOT ALONE!!!
If I fix mine this sunday, I will prepare a lengthy report on my findings.
Distortion 5.0 is offline
post #3 of 20 (permalink) Old 02-02-2007, 10:42 PM
The Great Obucina's Avatar
i bet you bottom dollar its the upper arm bushings. Which are serivceable. TRW makes a replacement and they must be pressed out.
which strut rod bushings are you running? both on the arm and frame. Moog thermoplastic el crack-o-matics i have and hate. TRW - in a real TRW box are rubber and much better.
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 20 (permalink) Old 02-03-2007, 04:27 PM Thread Starter
I replaced the complete UCAs little over a year ago & the boots are still intact. The strut rod bushings were from Ford. there are no Moog parts on the car
Bymet is offline
post #5 of 20 (permalink) Old 02-03-2007, 11:23 PM
no, i mean the bushings on the arms.....where the arm bolts to the frame. jack up the car and disconnect the ball joint from the spindle and shake it. if you get a rattle, theres your sign. Mine went south after about a year.
post #6 of 20 (permalink) Old 02-16-2007, 03:28 PM Thread Starter
The UCA bushings are fine. It only happens when I'm backing up & turning the wheel. The end links are the only part that moves with the spindle so I'm beginning th think the sway bar end links are the problem even though they are only a little over a year old.
Bymet is offline
post #7 of 20 (permalink) Old 02-16-2007, 06:50 PM
Steering rack and pinion.
Hollywood Ed is offline
post #8 of 20 (permalink) Old 02-16-2007, 08:29 PM
96bird's Avatar
Mine makes the same sound sometimes when I back up while turning the wheel. I will be anxious to see what you come up with.
Russ
96bird is offline
post #9 of 20 (permalink) Old 02-16-2007, 08:37 PM
Jim I have the same problem. And I just did my UCA, Lower, and everything else about 6 months ago. I can't solve it.
94ONAIR is offline
post #10 of 20 (permalink) Old 02-17-2007, 11:52 AM Thread Starter
It is less than 2 years old & doesn't leak. Also if it was the rack & pinion why would it make noise only when backing up?
Bymet is offline
post #11 of 20 (permalink) Old 02-17-2007, 11:52 AM Thread Starter
Alex
Did you get your car back yet?
Bymet is offline
post #12 of 20 (permalink) Old 02-17-2007, 12:35 PM
check the sub frame bolts I did everything you did and tightening the one loose bolt was the fix.
post #13 of 20 (permalink) Old 02-18-2007, 03:08 AM
thewishkah's Avatar
Send a message via AIM to thewishkah
My friend with a mustang 4.6 had this same issue from when he bought the car (2005) its a 2004 the person who had it before him hit one of those tire stops in a parking lot and well it hit more then the tires. He ended up having to replace the whole rack and bushings, just a thought since he had the same issue.
thewishkah is offline
post #14 of 20 (permalink) Old 02-18-2007, 12:01 PM Thread Starter
Thanks for the input. I haven't hit anything with it so I don't think it's the rack
Bymet is offline
post #15 of 20 (permalink) Old 03-18-2007, 10:54 PM Thread Starter
Well I replaced my struts & sway bar end links this weekend & it did not solve the problem. This may sound dumb but where exactly are the sub frame bolts located?
Jim
Bymet is offline
post #16 of 20 (permalink) Old 03-20-2007, 03:06 PM Thread Starter
Jim
Anyone have an answer for me on this?
Bymet is offline
post #17 of 20 (permalink) Old 03-20-2007, 03:51 PM
Nick's Avatar
I had a similar issue when I installed 13" rotors and larger calipers on the front. It seem'd that the calipers were on the wrong sides L/R. Cleared up when I put them on the correct side. Seemed to happen when turned the wheel and backing up. I know you didn't mention a brake conversion, but thought I'd toss it out there just in case. Sounds like you went through a big chunk of the front suspension.
Xcal2-tuned by Lonnie* Jmod kit by Darrin/Alan* '04 Marauder T/C*2002 GT MAF/airbox/intake tube* '04 explorer PI 4.6L/P&P by steenracing* Comp Cams - XE262AH* Accufab Plenum/ 75mm Throttle Body* 30lbs. injectors* 190lph fuel pump* 180* T-stat* Motorcraft 22C's* Steeda U/D pullies* JBA Ceramic Coated Headers* Aluminum Driveshaft* FRPP Aluminum pumpkin 3.73*
not installed yet:Suspension stuff: JL rstb/lower engine cradel brace/subframe connectors* KB FSTB* MN12Performance solid engine mounts/trans mount/poly crossmount bushings/IRS Diff bushings/Rear Cover Brace*RE6 Slam Specialites bags in the rear* Viair 400C compressor* 5gal Firestone tank* (8)Parker 1/2"valves* Dakota Digital Guage
Nick is offline
post #18 of 20 (permalink) Old 03-20-2007, 07:00 PM Thread Starter
Yes I did a 13" brake upgrade about 3 years ago. This noise started a few months ago. I'm thinking somethig is loose enough that it moves causing the popping noise when I'm turning while backing up. Sub frame bolts make sense to me. I just need to know where they are exactly
Bymet is offline
post #19 of 20 (permalink) Old 04-09-2007, 02:45 PM Thread Starter
Front sub frame bolts were the problem. They weren't loose but they were below the torque specs. Got an E18 torx socket & tightened them up to about 90 ft/lbs & the popping went away. Checked the rears as well & they were OK. As old as these cars are getting it's not a bad idea check these things every few years.
Thanks for the suggestion
Jim
Bymet is offline
post #20 of 20 (permalink) Old 04-13-2007, 12:51 PM
Jim
That is an awesome find. I have some popping in my front end and that's something I'll check first. I like to keep it as simple as possible at first.....
96gts4.6L is offline
