What is this called? help please! - TCCoA Forums
post #1 of 27 (permalink) Old 02-22-2007, 03:22 PM Thread Starter
okay guys, on our front suspension what is the arm circled in red called, and also I need the bushings circled in blue, got some metal on metal rubbing, any thoughts ideas, help~! thanks
sorry guys, got it fixed!
mike884_2 is offline
post #2 of 27 (permalink) Old 02-22-2007, 03:24 PM
Traveler's Avatar
Need a better pic than a red "X"
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #3 of 27 (permalink) Old 02-22-2007, 03:25 PM Thread Starter
fixed it, thanks
post #4 of 27 (permalink) Old 02-22-2007, 03:34 PM
Traveler's Avatar
LOL Well, now that I can see the part......... I don't know the name of it either.. Sorry I couldn't be more help. But I am anxious to see what its called!
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 27 (permalink) Old 02-22-2007, 03:39 PM
jk69cat's Avatar
its called a front strut rod bushing, that is the front position, and its pn is e9sz.3a187.a
mn12 less!
jk69cat is offline
post #6 of 27 (permalink) Old 02-22-2007, 04:06 PM
Banned
is it a kit that comes with 2 bushings for each side of the strut bar?
before the bar attaches to the frame the bushing is worn out. On the other side of the frame where the strut bar has a bushing and nut to hold it down the bushing looks 75% gone.
Do i need to order 2 or does a kit come with both sides?
sorry to hijack the thread but i think the info outcome will help us both...
Porkchop is offline
post #7 of 27 (permalink) Old 02-22-2007, 05:13 PM
jk69cat's Avatar
yes that is a kit , bushings , sleeves, washers, nuts
mn12 less!
jk69cat is offline
post #8 of 27 (permalink) Old 02-22-2007, 05:24 PM
David_viny's Avatar
I think another technical name for the rod it is a "tension strut," but I mentioned that to the Ford place in town and got the blank stare.
You can get some cheap bushings at rockauto.com, but some people say they wear out fast. I never tried them so I don’t know.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #9 of 27 (permalink) Old 02-22-2007, 05:36 PM
Banned
for one side only? does the last letter specify the side? if so whats the number for a passenger side kit? is that motorcraft?
Porkchop is offline
post #10 of 27 (permalink) Old 02-22-2007, 06:12 PM
In the service manual the bar is referred to as the front suspension lower arm strut. The bushing for the bar are called strut rod bushings, so I think it's safe to call the thing a strut rod.
post #11 of 27 (permalink) Old 02-22-2007, 06:50 PM
jk69cat's Avatar
porky, you'll need 2 , one kit does one side
mn12 less!
jk69cat is offline
post #12 of 27 (permalink) Old 02-22-2007, 07:33 PM Thread Starter
well thanks guys, my front end has been rattling around, and i finally found that they were pretty worn out, and showing some rubbed metal, hopefully this will fix!
post #13 of 27 (permalink) Old 02-23-2007, 12:14 AM
Banned
is that number the pass or driver side?
Porkchop is offline
post #14 of 27 (permalink) Old 02-23-2007, 01:06 AM
It's the same for both sides.
post #15 of 27 (permalink) Old 02-23-2007, 01:14 AM
Banned
saawweeeeeeeeet thanks guys...looks like i have a weekend project as well..
Porkchop is offline
post #16 of 27 (permalink) Old 02-23-2007, 10:59 AM
I'll add my thanks for the info as well, as this is one of the areas of my front suspension that needs to be addressed before my '92 can be inspected.
92 Sport is offline
post #17 of 27 (permalink) Old 02-23-2007, 11:02 AM
The Great Obucina's Avatar
DO NOT BUY Moog strut rod bushings! FYI. Get the Ford stuff.
trust me.
"Booyah". Stu Scott.
The Great Obucina is offline
post #18 of 27 (permalink) Old 02-23-2007, 01:14 PM
trust me.
Duly noted. Thanks!
92 Sport is offline
post #19 of 27 (permalink) Old 02-23-2007, 03:38 PM Thread Starter
man looks like a lot people had the same problem, but a lot of people are now benefiting
post #20 of 27 (permalink) Old 02-23-2007, 07:04 PM
bad93bird's Avatar
Why not buy Moog? Don't put a wrench on the flat part of the strut rod. The service manual says not to. I don't know why. It is just a bad thing to do. If you put a wrench on the ends of the flat areas you are ok. Not in the middle of it. Where do those part numbers go? Which dealer or store?
QUADSQUAD MEMBER
bad93bird is offline
post #21 of 27 (permalink) Old 02-23-2007, 07:07 PM
the moog material is thermoplastic and not very stable. I have been through 3 moog bushings in the past 4 years. Also, there are susceptible to petrochemical breakdown, if you have a minor trans line or PS leak, the mercon will eat the bushing in no time.
post #22 of 27 (permalink) Old 02-23-2007, 07:09 PM
http://forums.tccoa.com/showthread.p...ut+rod+bushing
post #23 of 27 (permalink) Old 02-28-2007, 07:19 PM
bad93bird's Avatar
O.K. so where do I get them at? I'd like some polyurethane ones. I think the OEM ones will work. The bushing on the passenger side it good. The driver side bushing had deteriorated. It is OEM I believe.
QUADSQUAD MEMBER
post #24 of 27 (permalink) Old 03-01-2007, 02:23 PM
chunk is offline
post #25 of 27 (permalink) Old 03-01-2007, 06:37 PM
trust me.
Don't be HATEING! /sarcasm
I mean just because there crappy bushings is no reason to be hateing! You know i'm so sick and tired of hearing that corny phrase when you point anything negative out to some people. lol
Southpaw is offline
post #26 of 27 (permalink) Old 03-01-2007, 06:49 PM
The manual says...
CAUTION: Do not hold front suspension lower arm strut (3468) or damage surface in area shown. Hold front suspension lower arm strut on flats with wrench. Remove front sub-frame retaining nut.
the area they warn not to damage is the immediate area around the bend in the strut rod. My assumption when I read that awhile ago was that this is an easily weakened spot if mishandled and the strut rod is a critical front suspension component. Thus the warning not to beat it all up like a caveman with your wrench.
Southpaw is offline
post #27 of 27 (permalink) Old 03-02-2007, 12:08 AM
Texas Chapter Director
Send a message via AIM to speed95 Send a message via Yahoo to speed95
You can get the TRW brand at Advance Auto. I replaced all my front end with TRW bushings. The bird rides super smooth now.
speed95 is offline
