aaaarrrrrrggggghhhhh!!!!!!!!!!!! - TCCoA Forums
post #1 of 17 (permalink) Old 02-25-2007, 12:11 PM Thread Starter
i f-----n hate ball joints. this thing is kickin my butt. just needed to rant a little
v8pwrdbird is offline
post #2 of 17 (permalink) Old 02-25-2007, 01:10 PM
jk69cat's Avatar
why they are pretty darn simple
mn12 less!
jk69cat is offline
post #3 of 17 (permalink) Old 02-25-2007, 01:39 PM Thread Starter
i cant get the lower ball joint to press all the way on. two days later still tryin
post #4 of 17 (permalink) Old 02-25-2007, 01:48 PM
The Great Obucina's Avatar
digress please.
you mean the ball joint onto the arm or the ball joint onto the spindle?
"Booyah". Stu Scott.
The Great Obucina is offline
post #5 of 17 (permalink) Old 02-25-2007, 01:59 PM
jk69cat's Avatar
again, stop , step away from the car, go buy a set of lca's and a set of strut rod bushings. just you can buy the ball joints seperate .doesnt mean you should. these cars are old and its more cost/time effective to replace the whole darn thing
mn12 less!
jk69cat is offline
post #6 of 17 (permalink) Old 02-25-2007, 02:48 PM Thread Starter
i mean actually pressing the ball joint in. it is stuck w/ about 1/8" left. i cant seem to press it on any further
post #7 of 17 (permalink) Old 02-25-2007, 02:51 PM Thread Starter
who carries the LCA. autozone aint got em
post #8 of 17 (permalink) Old 02-25-2007, 03:25 PM
gcash81001's Avatar
Send a message via AIM to gcash81001 Send a message via MSN to gcash81001
advance auto by my house had them
1994 Lincoln Mark VIII
2005 Ram 1500 Hemi
1974 Chevy Nova
2003 Ford Crown Victoria
XBL & PSN: Gcash81001
gcash81001 is offline
post #9 of 17 (permalink) Old 02-25-2007, 07:36 PM
you need a floor mounted hydraulic press for the ball joints.
post #10 of 17 (permalink) Old 02-26-2007, 07:44 PM
I used a floor mounted press and it still gave me problems with not wanting to seat like yours. I ended up pressing the joint back out and wire wheeling the insides of the arm to "clean them up", then used penetrating oil and pressed it back in. It was stiff again, but seated after that. In the future just shell out for the entire LCA, I know I will.....
JohnNaas is offline
post #11 of 17 (permalink) Old 02-26-2007, 09:16 PM
Wouldn't it go together easier if you stuck the bj's in the freezer for a few hours first? Especially if you heated up the control arms in the oven at the same time.
Nick
NickM is offline
post #12 of 17 (permalink) Old 02-26-2007, 10:17 PM
Mod Motor Cat's Avatar
~Brian~
*1990 Mustang Coupe, 5.4L*
Black on Black & Stroked 'n' Polked!!!
Mod Motor Cat is offline
post #13 of 17 (permalink) Old 02-27-2007, 03:52 PM
frankjc's Avatar
Send a message via Yahoo to frankjc
Originally Posted by Mod Motor Cat View Post
Gotta love the BFH.
Seriously, go with the whole arm when you need lower ball joints. Not much more expensive to go that way, and well worth it.
Drive it like you stole it!
frankjc is offline
post #14 of 17 (permalink) Old 02-27-2007, 08:04 PM
Resident drifter
slidebird91's Avatar
use one of these, that'll take care of it
slidebird91 is offline
post #15 of 17 (permalink) Old 02-27-2007, 08:19 PM
Traveler's Avatar
LOL Yea, that'd make a lot of tasks easier. Can't get that exhaust cut in just the right place? SLICE! Not to mention handling road rage!!
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #16 of 17 (permalink) Old 02-28-2007, 03:29 AM
4.3Lcougar's Avatar
autozone has a ball joint press to rent for 100 bucks, its pricey, but i was using the hammer and everything. i got tired of messing with it after 4 days and finally rented it... but i found out that if you use some bushing grease it slides in a lot easier... just my 2 cents.
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #17 of 17 (permalink) Old 02-28-2007, 08:56 AM
frankjc's Avatar
Use the force.
frankjc is offline
