Question for guys running moog uca's - TCCoA Forums
post #1 of 10 (permalink) Old 02-28-2007, 07:41 AM Thread Starter
coggonobrien's Avatar
i see the grease hole on top of the ball joint. to be able to grease them are we supposed to add a screw in zirc or is there a special tool to do it? thanks, Dave
coggonobrien is offline
post #2 of 10 (permalink) Old 02-28-2007, 09:59 AM
drag-aholic
BAGGED89's Avatar
if they have the blue ball joint boot they should have a zirk fitting. i can't remember if i had to put it in or it if was installed. The other arms with the clearish boot don't have that fitting hole.
1989 LX Full Air Suspension
BAGGED89 is offline
post #3 of 10 (permalink) Old 02-28-2007, 10:07 AM Thread Starter
mine have a black boot
post #4 of 10 (permalink) Old 02-28-2007, 10:09 AM
drag-aholic
BAGGED89's Avatar
then I don't know sorry
BAGGED89 is offline
post #5 of 10 (permalink) Old 02-28-2007, 10:12 AM Thread Starter
i'll try and get some pics of them up today sometime
post #6 of 10 (permalink) Old 02-28-2007, 10:15 AM
drag-aholic
BAGGED89's Avatar
i cant image a hole in the upper balljoint for anything other than a zerk fitting. Mine have either had the hole with a zerk or was sealed.
BAGGED89 is offline
post #7 of 10 (permalink) Old 02-28-2007, 10:38 AM
Mine came with the fitting in a small bag inside the box. The fittings just thread into the hole using a wrench/ratchet, nothing special needed.
slobird is offline
post #8 of 10 (permalink) Old 02-28-2007, 10:43 AM Thread Starter
son of a ..... the zerk was in the bag, i just hadn't noticed it since i quickly looked at the bag without opening it and saw just the big bolt and instructions. thanks for the help
post #9 of 10 (permalink) Old 02-28-2007, 12:05 PM
richuncle's Avatar
Pretty big newb here. I'm just curious, how often should I be regreasing these things? I installed the Moogs maybe 5k miles a go. Also how do you know how much grease to put in. Initially I just filled that sucker up. Figured too much grease couldn't hurt, just make a mess
richuncle is offline
post #10 of 10 (permalink) Old 02-28-2007, 05:09 PM Thread Starter
ur right on the the amount of grease. just fill it til it won't take anymore, it'll squirt out the zerk b4 it breaks a seal elseware
