dragrace settings - TCCoA Forums
post #1 of 6 (permalink) Old 03-10-2007, 04:53 PM Thread Starter
dragrace settings
what do the rear toe & camber settings need to be for the drag strip with bf goodrich g-force drag tires
raceman408 is offline
post #2 of 6 (permalink) Old 03-10-2007, 04:59 PM
Banned
i would say slightly toe in and slight positive camber so when you launch hard the weight going towards the rear will straighten out the rear tires?
just a theory.
Porkchop is offline
post #3 of 6 (permalink) Old 03-11-2007, 09:46 AM Thread Starter
dragrace settings
ok, i lowerd my car 2in and now it wont hook up
post #4 of 6 (permalink) Old 03-11-2007, 02:21 PM
Banned
how did you lower it and what brand of springs did you get? there is more than one type of spring setup that will affect ride quality. did you lower it so much you affected your camber? there is so much more for drag settings than lowering a car.
Porkchop is offline
post #5 of 6 (permalink) Old 03-11-2007, 03:29 PM Thread Starter
dragrace settings
i dont know what brand they are, i got them used they lowred it 2in, we sat the camber back to 0, this is on street tires, i have a set of bf gr drag tires that i am going to run at the track have not been to the track yet. whats funny is it would not spin but maybe 2 feet before on the road now it will spin them about 3 car lenths or more, is it because that it was high in the back that the axles had a lot of angle on them that they were in more of a bind, the axles are close to level now
post #6 of 6 (permalink) Old 03-13-2007, 11:18 AM
T6Rocket's Avatar
The axle angle has nothing to do with it.
It spins more now cause the front end doesnt lift as much, and the weight isnt transferring as good.
I know it's not the same car, but my Supra used to have Eibachs on it, 1 1/2" lowered. Car did not hook great. Switched to stock springs, car hooks great now!
Lowering springs = good lateral grip, but no hook at the track. If you want to to hook, switch em back!
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
