I F'd up big time, I need advice - TCCoA Forums
post #1 of 9 (permalink) Old 03-19-2007, 01:08 AM Thread Starter
I was torquing down the nuts that retain the top of a strut assm. last night and I stripped a nut because I read the wrong torque specs for a ford part instead of a monroe part. So I went and bought a new nut and washer from home depot and at worked its self tightening magic so well it snapped the strut stud before I reached the torque specs for monroe!!! Im clearly new at this and want to fix this if possible with out buying the new strut again. Im going to have a shop drill out the stud tomarrow but I have to drive the car there is that dangerous??? Can this be fixed with a new nut and bolt? I know there is some real experience here and thats why I love this board. I also need the car aligned so it drives funny to me when steering.
post #2 of 9 (permalink) Old 03-19-2007, 01:20 AM
drag-aholic
BAGGED89's Avatar
the single bolt for the top of the shock (call it a shock here ) or one the 3 bolts that hold the upper mount to the car?
1989 LX Full Air Suspension
BAGGED89 is offline
post #3 of 9 (permalink) Old 03-19-2007, 01:52 AM Thread Starter
one of the 3 little ones on the shock the one in the middle to be more exact.
post #4 of 9 (permalink) Old 03-19-2007, 02:01 AM
Well put it this way. I also broke off one of those little studs when I changed my shocks. That was over 2 years and 28,000 miles ago. You'll be fine, although it probably is best to repair it somehow either with a new bolt/nut or a new shock mount.
post #5 of 9 (permalink) Old 03-19-2007, 02:02 AM
dDUBb's Avatar
2 out of 3 bolts isnt bad. Alot of the weight of the car is going to be holding it down anyways, its not going anywhere.
- Dan
dDUBb is offline
post #6 of 9 (permalink) Old 03-19-2007, 02:07 AM
They would be the 'Upper Shock Mount to Body' which would normally be torqued to 17-22 lb/ft (22-31 N-m). You could take the mount out and drill out the remaining end of the stud and replace it with a bolt. Although the chore of trying to put that in and hold it in place might be near impossible. The $30 for a replacement upper mount may be money well spent (and it is definitely well spent if the age/mileage of the car is high or they show any signs of delaminating. It is a part that does wear out.
tbirdbrain is offline
post #7 of 9 (permalink) Old 03-19-2007, 02:59 AM Thread Starter
So I should be ok to drive to my local shop 10 minutes away
post #8 of 9 (permalink) Old 03-19-2007, 08:40 AM
T-bird_fan's Avatar
Send a message via Yahoo to T-bird_fan
You should be more then fine, like said before it only holds the top mount to the body and keeps it from rotating. Since you have the other two bolts to do this I would just keep an eye on it to make sure the stock is not sliding around againest the body.
J-Mod, MMC D/S, 24k gvw Tranny Cooler, Mark VIII TC,13” KVR Frt brakes, FRPP 3.73 rear, PI cams & Intake plus P&P NPI heads with the cooling mod, 1 3/8" Rr swaybar.
T-bird_fan is offline
post #9 of 9 (permalink) Old 03-19-2007, 08:30 PM
I replaced mine when I did my rebuild. Worst thing is you are now going to have to disasemble the entire strut assembly
97TXBIRD is offline
