Front end rebuild parts list? - TCCoA Forums
post #1 of 1 (permalink) Old 03-20-2007, 09:58 AM Thread Starter
Nick's Avatar
Question Front end rebuild parts list?
I have read about people rebuilding the front ends, and how they are getting a smoother ride. I figure since that I'm close to 110,000 miles, and I hear a rattle sound when hitting some bumps in the road, it must be time. I have come accross the following parts list, was wondering if I missed much, or if maybe there are some things that might not need to be changed. Also, are greasable units better than non-greasable? Looking for suggestions for my shopping list.
Lower Control Arms (greasable) $92.54 ea (retail $140.22 ea)
F5SZ-3079-A
F5SZ-3078-A
Upper Arms (greasable) $44.95 ea (reatail $66.02)
F3SZ-3V085-A
F3SZ-3V084-A
Upper Arms (non-greasable) $64.49 (retail $97.72)
F3SZ-3085-A
F3SZ-3084-A
bushings located front of lower control arm $7.67 ea (retail $11.12 ea)
E9SZ-3A140-A x2
bushings located at rear of lower control arm $4.51 ea (retail $6.55 ea)
E9SZ-3A140-B x2
strut rod bushing repair kit $46.83ea (retail $62.43) k-member
E9SZ-3A187-A x2
Inner Tie Rods $23.86 (retail $43.98)
F6SZ-3280-BA
Outer Tie Rod end $23.85 ea (retail $42.95 ea)
F4SZ-3A130-A
Strut Rod $53.22 (retail $80.62)
F3LY-3468-A
FYI - that was from a past post, and prices are not current.
Xcal2-tuned by Lonnie* Jmod kit by Darrin/Alan* '04 Marauder T/C*2002 GT MAF/airbox/intake tube* '04 explorer PI 4.6L/P&P by steenracing* Comp Cams - XE262AH* Accufab Plenum/ 75mm Throttle Body* 30lbs. injectors* 190lph fuel pump* 180* T-stat* Motorcraft 22C's* Steeda U/D pullies* JBA Ceramic Coated Headers* Aluminum Driveshaft* FRPP Aluminum pumpkin 3.73*
not installed yet:Suspension stuff: JL rstb/lower engine cradel brace/subframe connectors* KB FSTB* MN12Performance solid engine mounts/trans mount/poly crossmount bushings/IRS Diff bushings/Rear Cover Brace*RE6 Slam Specialites bags in the rear* Viair 400C compressor* 5gal Firestone tank* (8)Parker 1/2"valves* Dakota Digital Guage
Nick is offline
