intrax spings - TCCoA Forums
post #1 of 12 (permalink) Old 03-20-2007, 05:41 PM Thread Starter
Merlon's Avatar
intrax spings
so i have a set of intrax lowering spings in my car right no. the front is supposed to be dropped 2", and the rear 1.8"
the rear is lower than the front!!anyone know how to get it to look even, and no its not the look of the body line, the rear is way lower than the front.
ive let them settle, been a month, whats up?
anyone else have this problem, and how did you fix it?
it has been on a lift by the way, since the lowering, so maybe it needs to settle some more?
00 GT transmission,Jmod,30,000 gvw transmission cooler
Air silencer removed(cone filter added w/ heatshield)
shaved emblems, doors, trunk, and antenna
Clear corners
chrome 95sc rims
20% tint all the way around,
6gallon air tank capacity, Viair 400c commpressor
175psi pressure switch
custom guages by Scott H.
http://www.cardomain.com/ride/2733945
Merlon is offline
post #2 of 12 (permalink) Old 03-20-2007, 05:42 PM
Banned
let it settle, or time to cut the springs? lol
Porkchop is offline
post #3 of 12 (permalink) Old 03-20-2007, 08:00 PM Thread Starter
Merlon's Avatar
serously its been a month at least? i dont know for sure, but i dont think that putting it on a lift would make the springs need to settle again...yes?...no?
Clear corners
chrome 95sc rims
Merlon is offline
post #4 of 12 (permalink) Old 03-20-2007, 08:27 PM
TwoHaggard's Avatar
doesnt SCP have airlift bags. lift it up alil and help wheel hop too.. i allso have 2'' intrax and its pretty low. back a lil lower seems like.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #5 of 12 (permalink) Old 03-20-2007, 08:27 PM
sCrEaMiN BiRd's Avatar
My eibachs were the same way. I ended up cutting my eibachs in the front.
sCrEaMiN BiRd is offline
post #6 of 12 (permalink) Old 03-20-2007, 08:34 PM Thread Starter
Merlon's Avatar
yeah but i like it low...
i would mind wheel hop deletion..might have to cut it...
how much did you cut the eibachs? screamin bird?
Clear corners
chrome 95sc rims
Merlon is offline
post #7 of 12 (permalink) Old 03-20-2007, 08:47 PM
I cut a quarter coil off of the front. Took about a 1/4" from the front. At the same time i replaced my front struts with KYB's. With the eibachs i actually wouldn't mind cutting all my springs a little more. I kinda wish i went with intrax springs. The eibachs are not low enough at all. Needs to be about 1/2" lower, maybe more, on all 4 corners (this is after i cut my springs in the front).
post #8 of 12 (permalink) Old 03-21-2007, 06:24 AM
twin turbo 281's Avatar
I dont like the spring rate on the intrax they need to be stiffer there pretty much just for looks but I do like the ride height
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #9 of 12 (permalink) Old 03-21-2007, 09:48 AM
Did you have the weight of the car on the lower arm when you tightened everything up? It made a big difference on mine. It didn't look right when I tightened down everything with the suspension hanging.
I loosened up everything (UCA bushing to tower, lower shock mount are the main 2) and jacked up the suspension under the spindle until all the weight was on it then did the lower shock mount and the UCAs. Not only did it seem to settle right away to a better height, but it was quieter also.
Bangster is offline
post #10 of 12 (permalink) Old 03-21-2007, 10:04 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
I think Intrax springs are known for sagging in the rear.
Sold = 96 Thunderbird
Aaron K. is offline
post #11 of 12 (permalink) Old 03-21-2007, 01:38 PM
The Great Obucina's Avatar
Si! and jamex.
"Booyah". Stu Scott.
The Great Obucina is offline
post #12 of 12 (permalink) Old 03-21-2007, 09:41 PM
I did this also. Loaded the suspension before tightening everything. For whatever reason my car still sat high in the front. So i ended up cutting my eibachs as i said before. But i have tried this technique on some of my other cars before and it did seem to level out the car.
