what isolatorers to use? - TCCoA Forums
post #1 of 7 (permalink) Old 03-23-2007, 08:28 AM Thread Starter
i have a 92 5.0 bird, i need to replace the spring isolators, what was the trick wth using 2 sets of the cobra, or where do i get the energy suspension kind?
25svo is offline
post #2 of 7 (permalink) Old 03-23-2007, 04:01 PM Thread Starter
bump i know this has been talked about on here before
25svo is offline
post #3 of 7 (permalink) Old 03-23-2007, 04:20 PM
David_viny's Avatar
Might find some here.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #4 of 7 (permalink) Old 03-23-2007, 07:15 PM
Waldorf's Avatar
Try the Prothane Isolators
The Prothane spring isolators are really for an IRS Cobra. I got mine at: Laurel Mountain Mustang
You'll need Flash Player to access the site (hate it!). Once you're there, it's under "Late Model" then "Chassis Components" "Prothane & Polyurethane Bushings". Near the bottom of the chart is "1999-04 Cobra IRS Coil Spring Insulators 6-1709BL" The price is per pair, so you'll need 2 sets. The Cobra only uses them on the LCA, but an MN-12 uses an upper and a lower for each side, which are the same size. I've ordered from them a few times with no problems.
I'll try to post a pic later tonight (need batteries)... I've had the isolators for quite a while, but just got new springs today. Just checked - they definitely DO fit.
Best of Luck!
That is all...
Experience is simply knowing what not to do... and knowing what won't work.
The Car... 324,201 and still goin' strong; Me... I'm NOT a complete idiot - still missing a few parts.
Waldorf is offline
post #5 of 7 (permalink) Old 03-23-2007, 08:33 PM
Waldorf's Avatar
25svo,
Here's what one looks like:
The spring is a Tokico rear, and the spring perch is for mounting into a MKVIII lower control arm. Just make certain you lube them up really well with silicone grease, like this:
Silicone Grease
The Prothane spring isolators DO NOT come with grease. Use a silicone based grease, NOT a petroleum based one.
That is all...
Waldorf is offline
post #6 of 7 (permalink) Old 03-25-2007, 08:10 AM Thread Starter
that for the pic but i do know what the are,do, look like,
i just needed the part # hopefully i can get them in yellow but i doubt it
25svo is offline
post #7 of 7 (permalink) Old 03-25-2007, 08:47 AM
Waldorf's Avatar
The point of the pic was to show that they fit.
According to their catalog:
Colors
PROTHANEā„¢ kits are stocked only in RED or BLACK polyurethane. NOTE that all part numbers listed are for RED kits, if BLACK is desired, you must add the code-BL to the end of the part number. Other colors may be available by advanced special ordering only when quantity minimums and other requirements are met.
That is all...
Waldorf is offline
