Front end question - TCCoA Forums
post #1 of 4 (permalink) Old 03-27-2007, 07:28 AM Thread Starter
Jack of all trades, Master of none
bobbylx's Avatar
Front end question
Okay, so I was checking out my front tires and noticed that my drivers side front tire has a really bad uneven wear. The outside edge of the drivers front is wearing out much faster than the rest of the tire. There's a strip about 2 inches wide that has all the tread worn down, while the rest of the tire looks good. The passenger side is completely normal. Does this sound like a camber issue? I know the alignment is off slightly, but I figured both tires would show wear with an alignment problem.
And, if it is a camber problem, is this something I could correct myself and how?
Deaf and blind and dumb and born to follow
what you need is someone strong to guide you
bobbylx is offline
post #2 of 4 (permalink) Old 03-27-2007, 09:42 PM
thewishkah's Avatar
Send a message via AIM to thewishkah
maybe your just taking right hand turns to fast lol j/k It sounds like a + chamber issue to me.
thewishkah is offline
post #3 of 4 (permalink) Old 03-28-2007, 12:32 PM
rtalber1's Avatar
It is alignment for sure, get it fixed. Probably a bad Tie Rod.
Big Rob's Car---1998 Lincoln Mark VIII LSC Collector's Edition #314 in Cordovan Red. 89,xxx miles----
1997 T-BIRD LX 116,xxx miles--- Lost Due to a Divorce!!!
rtalber1 is offline
post #4 of 4 (permalink) Old 04-04-2007, 08:40 PM
Waldorf's Avatar
I'll second that. Sounds way too positive (out at the top). If your front end is tight (no worn out parts) and it's worn smoothly without being cupped very much, it's a camber issue. A bad tie rod, or improper toe-in usually wears the tire sort of sawtooth. The rubber between each circumferential groove is high on one side and low on the other. It seems the wider the tire, the faster and further in it wears.
If all 4 tires are the same size, you might rotate that front tire to the rear before getting it lined up. Mine have always worn on the inside on the rear. If yours is like mine, you can then wear the inside 2" of tread down.
That is all...
Experience is simply knowing what not to do... and knowing what won't work.
The Car... 324,201 and still goin' strong; Me... I'm NOT a complete idiot - still missing a few parts.
Waldorf is offline
