Eibachs? - TCCoA Forums
post #1 of 10 (permalink) Old 04-05-2007, 05:02 PM Thread Starter
gcash81001's Avatar
Send a message via AIM to gcash81001 Send a message via MSN to gcash81001
Eibachs?
What up the these eibachs, I bought the springs from my friend, He had them on his tbird, I put the on two weeks later and the front sits almost a stock height on the rear is fine. I put new uca's and swaybar endlinks on the front, Why would the car sit so high in the front? The aligment is not the bad is the front too. Would the new uca's and endlinks make it sit higher?
1994 Lincoln Mark VIII
2005 Ram 1500 Hemi
1974 Chevy Nova
2003 Ford Crown Victoria
XBL & PSN: Gcash81001
gcash81001 is offline
post #2 of 10 (permalink) Old 04-05-2007, 08:43 PM
The Great Obucina's Avatar
mine were just fine. Pull the shock/spring assy and make sure everything is seated properly.
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 10 (permalink) Old 04-05-2007, 08:45 PM Thread Starter
gcash81001's Avatar
the thing is that his car sat fine, with them on, and 2 weeks later its all messed up on mine.
2005 Ram 1500 Hemi
1974 Chevy Nova
post #4 of 10 (permalink) Old 04-05-2007, 08:51 PM
then pull the shock/spring assy. The eibachs didnt grow.
post #5 of 10 (permalink) Old 04-05-2007, 08:54 PM Thread Starter
gcash81001's Avatar
i understand that, what else could be cause this?
2005 Ram 1500 Hemi
1974 Chevy Nova
post #6 of 10 (permalink) Old 04-05-2007, 08:58 PM
a spring not seated at its alignment point(s).
post #7 of 10 (permalink) Old 04-05-2007, 08:58 PM Thread Starter
gcash81001's Avatar
i never took the spings apart , the same shock and everything
2005 Ram 1500 Hemi
1974 Chevy Nova
post #8 of 10 (permalink) Old 04-05-2007, 09:00 PM
ok, then pull the assy and inspect the upper mount.
post #9 of 10 (permalink) Old 04-05-2007, 09:01 PM Thread Starter
gcash81001's Avatar
ok sure will, i will let you know
2005 Ram 1500 Hemi
1974 Chevy Nova
post #10 of 10 (permalink) Old 04-09-2007, 09:44 PM Thread Starter
gcash81001's Avatar
everything looks fine, the rear isolator must be worn out on mine, I getting new ones
2005 Ram 1500 Hemi
1974 Chevy Nova
