Sheared two bolts, Now what ? - TCCoA Forums
post #1 of 11 (permalink) Old 04-13-2007, 03:27 PM Thread Starter
I managed to bust both bolts on the rear subframe bracket. Is the any special tool i can use to back out the rest of the bolt ? Also the main bolt is still in there and the bracket was completely rusted away and that bolt won't budge ? Any helpful suggestions?
PI head and intake swap, J modded 99 trans w/ 3500 Stall Dirty Dog converter, Mark VIII drive shaft & pumpkin with 3.73 and sct tuned. Mid mount Magnaflow di/do, kyb's and springtech springs. Tuned by Precision Autosports.
Best time 13.91 @ 97
http://i3.photobucket.com/albums/y57...arterView2.jpg
henry74 is offline
post #2 of 11 (permalink) Old 04-13-2007, 04:39 PM
David_viny's Avatar
Ah, I busted one of mine when I replaced that bracket as well.
I drilled it out. I used a carbide center drill on it. Cuts like butter. Then I taped the hole to the next size up. If u can drill it straight enough, you might be able to save the threads.
1995 T-bird 4.6l - Eibach lowering springs, Cobra R hood, One 12" sub woofer, Alpine type-R front speakers. 16.249 @85.11mph 1/4 mile
2001 Pontiac Trans Am WS6 - Cam, headers, HPtuned by me.
David_viny is offline
post #3 of 11 (permalink) Old 04-13-2007, 04:43 PM Thread Starter
Thank you, can i do the same with the bolt where the bushing is attached? It doesn't seem to want to move at all.
henry74 is offline
post #4 of 11 (permalink) Old 04-13-2007, 05:23 PM
David_viny's Avatar
I’m not sure. The bushing would probably be in the way to get tools to the broken part if it snaps.
If it snaps, you might have to drop the whole sub frame to get the snapped bolt off. Mine actually came out good so IDK.
post #5 of 11 (permalink) Old 04-13-2007, 06:07 PM
Time for PB Blaster!
Jay
FordMan77 is offline
post #6 of 11 (permalink) Old 04-13-2007, 08:09 PM Thread Starter
Jay
Already working on 2nd day of the PB, blasted it again this evening and will try again tomarrow.
henry74 is offline
post #7 of 11 (permalink) Old 04-13-2007, 10:50 PM
conversion02's Avatar
Redrill it as david viny suggested. It's probably not the easiest to do initially, but it'll save you a lot of headaches in the long run.
conversion02 is offline
post #8 of 11 (permalink) Old 04-14-2007, 01:16 AM
Tweeeeka's Avatar
If it is the rear bolts on the subframe drill through the trunk floor and remove the bolts. Just measure carefully so that you don't cut the frame rails. Then the bolts just lift out, typical of ford they just use speednuts.
If the subframe is lying on the ground you can pick it up by using two jacks (one for the frame rail, one for the subframe then slide a couple bolts through the tabs all the way on the back of the subframe. Grind the heads so that they will fit through the holes in the frame rail. This will get the car back together enough to get in and out of a driveway.
Tweeeeka is offline
post #9 of 11 (permalink) Old 04-14-2007, 11:17 PM Thread Starter
Still no luck, I went out an bought the bolt out sockets and it wont budge. I haven't drilled the 2 outer bolts yet, maybe tomarrow on those 2 but that main bolt is kicking my a**.
henry74 is offline
post #10 of 11 (permalink) Old 04-15-2007, 04:37 AM
FordFanatic's Avatar
id bust out the torch and heat them up.
FordFanatic is offline
post #11 of 11 (permalink) Old 04-15-2007, 08:41 AM
tbirdtess's Avatar
Heat??
Hello
Remember there is alot in sound foam there. If you use heat becareful.
-->FIRE!!<--
I would keep drilling it out untill the easy-out pulls the bolt.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
