Brake pedal went to floor today - TCCoA Forums
 4Likes
  • 2 Post By T6Rocket
  • 2 Post By chopper3200
post #1 of 10 (permalink) Old 02-25-2019, 07:48 PM Thread Starter
Hi, stopping for a yellow light today my brake pedal when to the floor and it pulled to the left pretty good like there was no brake pressure on the right side. The brakes worked fine after this, normal stopping power. I'm wondering why this happened, I put on a new master cylinder and rebuilt the caliper piston seals and bled everything at all four wheels last summer. No problems until now. Anyone have any thoughts? Thanks.
chopper3200 is offline
post #2 of 10 (permalink) Old 02-26-2019, 06:03 AM
You have a leak.
The brakes are setup fr and rl, fl and rr, just to cut down on pulling issues.
I've had the factory lines fail, which spurts fluid everywhere, or the master cylinder is bad, leaking internally.
If it's the master cylinder, you'll need a booster too; it leaks bf into the booster, killing it too.
post #3 of 10 (permalink) Old 02-26-2019, 07:15 AM
quickford's Avatar
My 96 Thunderbird had the brake line along the left front fender in the engine bay and it rubbed on something metal and formed a hole there, which I discovered approximately 20 minutes into my ownership of the car.
Was lucky enough to find a place that could patch it up on a Saturday so I could make the 10 hour drive home.
Current poor life choices: 1991 Mercury Cougar XR7, 1998 Lincoln Town Car, 2005 Ford Focus ST, 1997 Ford Probe GT.
Previously: 2015 Focus, 1996 Thunderbird, 1998 Taurus, 1989 Escort.
quickford is offline
post #4 of 10 (permalink) Old 02-26-2019, 10:23 AM
T6Rocket's Avatar
That sounds like the previous owner stickin' it to ya. 20 days, maybe not. 20 minutes, hell yes.
Al
Trunk Monkey and CDsDontBurn like this.
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #5 of 10 (permalink) Old 02-27-2019, 11:41 AM Thread Starter
Thanks for the info Grog6 and quickford. I unbolted the master cylinder and don't see any sign of leaking behind it into the booster, it's all nice and dry. Can't find any fluid leaks anywhere, is it possible one of the edges of the seals in the master cylinder flipped over not allowing pressure to increase? It was a rebuilt unit and the brakes have been working fine since. I may just put a new master cylinder on.
post #6 of 10 (permalink) Old 02-27-2019, 01:17 PM
Urambo Tauro's Avatar
What about the combination valves over by the battery? Any leaks there?
Urambo Tauro is offline
post #7 of 10 (permalink) Old 02-27-2019, 07:14 PM Thread Starter
I don't see any leakage from the valves by the battery.
post #8 of 10 (permalink) Old 03-07-2019, 05:13 PM
I had that pulling to one side during sudden stopping (front left locked) when I first got my '97 Cougar. I don't remember the pedal falling to the floor however. My flexible brake lines were the culprit. Collapsing internally.
JPJP is offline
post #9 of 10 (permalink) Old 03-07-2019, 06:00 PM
Brake leaks don't fix themselves, so this may be something else. What year is this car? Does it have ABS? Disc or drum rear brakes? Before this happened had you just done a heavy stop from high speed?
post #10 of 10 (permalink) Old 03-12-2019, 03:15 PM Thread Starter
It's a 1997 without ABS, 4 wheel disc. I replaced the master cylinder with a brand new one, rebuilt the control valves, bled the system and that fixed it. The other master cylinder was less then a year old but a refurbished unit I got off eBay. When I took it out it felt like the edge of the seals were flipping over or damaged. Brakes work great now and feel better then they have in a long time.
Woodman and JPJP like this.
Similar Threads
1996 Thunderbird- Brake Pedal to Floor Urambo Tauro Brakes 13 04-11-2018 07:31 PM
Stiff brake pedal, brake and ABS lights are on... Drive XR7 Brakes 16 12-06-2009 11:53 AM
SC Clutch Pedal, Brake Pedal, Master Cylinder NICE! PICS! CometGSR Parts For Sale 5 06-02-2009 10:54 AM
Grey rear floor mats, grey SC seat floor bolt covers The_Ghost Wanted 0 08-14-2008 06:29 PM
