Brake Question - TCCoA Forums
post #1 of 7 (permalink) Old 03-21-2019, 05:05 PM Thread Starter
Brake Question
Hello all. So a couple days ago my passenger rear brake line broke and I lost all braking. Isn't there supposed to be some sort of braking? I mean shouldn't have I had brakes on two of the other wheels? When it went (the line) the pedal went to the floor and that was that.
Is this just the way they were designed or is there something I need to do so I can at least have partial braking if another line breaks.
This is on a '97 T-Bird.
Thanks!
barnsworth is offline
post #2 of 7 (permalink) Old 03-21-2019, 05:33 PM
Yeah, I was under the impression that there were two separate circuits. One linking LR/RF and the other RR/LF. Does the car have ABS? I am not sure if that throws that off...
97 Laser Red Thunderbird LX 159k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
98 Black Mark VIII 150k, stock daily driver
07 Redfire Fusion V6 SEL 176k, for the wife
post #3 of 7 (permalink) Old 03-21-2019, 05:40 PM
When a line breaks, the pedal does drop, but since you are here to talk about it, Iím betting you did still have some braking.
post #4 of 7 (permalink) Old 03-21-2019, 06:09 PM Thread Starter
I was under the impression too that there were two circuits too and if there was a failure you'd still have something else to stop you.
No there was absolutely no braking, held it to the floor and it kept on going until I popped it into neutral and stood on the parking brake. Thankfully I was just pulling out of a parking lot and didn't have any speed built up.
I'm just curious if there is something I need to repair that would make it work as it should. At least in my mind if there is a failure on one line there should still be some sort of breaking.
Thanks for the responses guys.
post #5 of 7 (permalink) Old 03-21-2019, 06:20 PM
Kenz's Avatar
Did you try pumping the brake pedal? When a rear line blew on the back of my Toyota, pumping it gave me some brake force. It would also lose all the fluid out of the master quickly that way, but at least it would slow down once or twice.
96 Cougar Sport - T45
96 Tbird LX
Kenz is offline
post #6 of 7 (permalink) Old 03-21-2019, 06:25 PM
There are 2 circuits. It is possible that you blew 2 lines simultaneously.
post #7 of 7 (permalink) Old 03-21-2019, 06:29 PM Thread Starter
No it wouldn't pump up. It just emptied fluid from the break in the line.
No only one line broke. I put a new line on it and the brakes are back to normal. Just a little concerned if another line breaks that's all.
Tags
brake , line
Similar Threads
SC hand brake and parking brake cables T-bird4vr Parts For Sale 2 10-08-2007 10:39 PM
Disc brake e-brake cable not working 94 Birdman Brakes 1 10-15-2003 01:42 AM
brake rotor question & separate brake problem question 66dvlbrd68 Tires/Wheels 0 10-11-2002 12:30 PM
Is it my brake pad, or my brake fluid? WaLieN General Tech 13 08-08-2002 03:27 AM
