Big Brake Package #2--Replacement Pads - TCCoA Forums
post #1 of 5 (permalink) Old 06-01-2019, 06:12 PM Thread Starter
Augustine1's Avatar
Does anyone know what size the pads are for the big brake package #2? Does it use the mustang gt or cobra pads? Or are these pads unique to this setup?
Augustine1 is offline
post #2 of 5 (permalink) Old 06-01-2019, 08:33 PM
Woodman's Avatar
Assuming you're talking about these...
https://www.supercoupeperformance.co...ont-brakes-244
They use 99-04 Mustang Cobra brake pads. You can piece this stuff together yourself from www.rockauto.com for much less money. You can also fairly easily extend the bolt holes on standard Cobra rotors to fit your stock MN-12 bolt pattern.
Woodman is offline
post #3 of 5 (permalink) Old 06-01-2019, 09:44 PM Thread Starter
Augustine1's Avatar
Awesome!!! Yes and thank you. I thought this was correct but couldn't remember.
post #4 of 5 (permalink) Old 06-01-2019, 10:24 PM
Exactly what I did. Cobra or Bullitt calipers, pads and rotors 99-04 are what you need. The calipers are the same but Cobra calipers "should" have COBRA in the castings. Not always what you find when you order a pair though!
post #5 of 5 (permalink) Old 06-01-2019, 11:39 PM
Mach 1 also. Bullitt and Mach one neither have Cobra cast in. It’s a crapshoot with remans since there are probably as many blank cores as “Cobra” cores in circulation
Similar Threads
3rd Brake Light Delete Package Tray Panel J_Mac57 Parts For Sale 24 11-13-2009 03:48 PM
Big rims..big brakes..i like it big time! rzibilske77 Videos/Images 47 06-13-2008 12:36 PM
Anyone using the 12" Baer brake package? upncumming Brakes 8 03-24-2005 11:21 AM
Rear Disk Pads replacement "Done the Easy Way" LST MN-12 Tires/Wheels 5 12-18-2003 12:41 PM
replacement brake pads in Canada? edgar Tires/Wheels 2 04-02-2003 09:48 AM
