Turn signal lever woes - TCCoA Forums
post #1 of 4 (permalink) Old 07-02-2019, 04:24 PM Thread Starter
My 1997 ordinary basic bird has a broken part on the turn signal lever. The knob that turns for the wipers is detached and wobbly. I can use the turn signal and I can spritz my windshield. DO you think I can attach it back on or does the lever need replacing?
venturahwy67 is offline
post #2 of 4 (permalink) Old 07-02-2019, 07:55 PM
I'm not sure I understand this post; You have a Broken Part, and you're asking if you should replace it?
post #3 of 4 (permalink) Old 07-03-2019, 04:08 AM
Replace it, search for Multi-Function Switch and how to replace it and you'll be good to go.
Welcome!
post #4 of 4 (permalink) Old 07-05-2019, 12:37 PM
CDsDontBurn's Avatar
I believe the OP is asking if he can fix his broken part or if the fix is to have the broken part replaced.
CDsDontBurn is offline
Similar Threads
1963 Thunderbird - turn signal lever Tbird Bob Miscellaneous 4 01-02-2015 11:23 AM
turn signal lever smokymance Audio / Electronics 5 01-18-2004 06:57 PM
Turn signal lever is loose... Drive XR7 General Tech 0 10-05-2002 04:49 PM
Moisture inside turn signal lense Wldcat8 Exterior 11 09-05-2002 10:04 PM
Alternatively Flashing Turn Signal Ashish Exterior 5 07-23-2002 10:12 PM
