93+ spindle swap - TCCoA Forums
post #1 of 12 (permalink) Old 11-26-2006, 08:02 PM Thread Starter
midnight toker
dameon's Avatar
Send a message via AIM to dameon Send a message via MSN to dameon Send a message via Yahoo to dameon
93+ spindle swap
ok I'm going to go ahead and change to the 93+ spindles from what I've read I will need to change the tie-rod ends as well, so here is my question, have any of you guys done it, and what parts/tools did you need? I plan on getting this done when I get my birdy back, and then I'm going to change over to the SN-95 hubs. thanks and ya I searched but I couldn't find anything particularly definate about whats needed and such, if there isn't one when I do I'll take enough pics to write one. thanks again guys.
-Frankie
--out on the western front
In Memory of Jose Calvetti
12-27-1974 - 7-23-2005
There is no replacement for displacement. Only ways to make the small dog act like the big dog
Originally Posted by Tx_Cat
... i do not have the tools nor the knowledge.
dameon is offline
post #2 of 12 (permalink) Old 11-26-2006, 10:10 PM
The only special tool you should need is a pickle fork to separate the lower ball joint and the tie rod end from the spindle. Otherwise, it's pretty straight forward. Then, when you do the hubs, you'll need a 250 ft-lb torque wrench. Don't forget to use new nuts with the new hubs.
It's only funny until someone gets hurt.
Then it's freaking hilarious.
Adventures in ChumpCar Racing
Tobey is offline
post #3 of 12 (permalink) Old 11-26-2006, 10:44 PM
jk69cat's Avatar
you dont need to change the tie rods , the only thing to change is the sway bar link and whatever brake parts you are going to use, btw if you dont have a pair of knuckles yet i have a set here
mn12 less!
jk69cat is offline
post #4 of 12 (permalink) Old 11-26-2006, 10:47 PM
rbrown's Avatar
And be careful when you use the fork. Make sure you slide it between the top of the boot and the arm. That way you do not tear the boot.
And Tobey. It wasn't that pulley. Need it back?
rbrown is offline
post #5 of 12 (permalink) Old 11-26-2006, 10:57 PM Thread Starter
midnight toker
dameon's Avatar
well I don't have anything yet, how much for the knuckles? and thanks for the feedback everyone.
dameon is offline
post #6 of 12 (permalink) Old 11-27-2006, 07:37 AM
No. The only idler pulley I have on mine is grooved. Go ahead and keep it in case you need it later.
Tobey is offline
post #7 of 12 (permalink) Old 11-27-2006, 07:52 AM
bad93bird's Avatar
It isn't real hard. Alot of people cry about that lower ball joint nut and trying to get it out of the spindle. Mine was simple. I don't recommed using pickle forks.
QUADSQUAD MEMBER
bad93bird is offline
post #8 of 12 (permalink) Old 11-27-2006, 09:40 AM
jk69cat's Avatar
hows 30 + shipping sound?
mn12 less!
jk69cat is offline
post #9 of 12 (permalink) Old 11-27-2006, 07:08 PM Thread Starter
midnight toker
dameon's Avatar
sounds pretty good you think you could give me an idea what shipping would be, it's hell paso, tx 79934. thanks
dameon is offline
post #10 of 12 (permalink) Old 11-28-2006, 09:27 AM
jk69cat's Avatar
ill get all the unneeded parts off and get an idea for you tommrow ,
mn12 less!
jk69cat is offline
post #11 of 12 (permalink) Old 11-28-2006, 04:29 PM Thread Starter
midnight toker
dameon's Avatar
cool thanks
dameon is offline
post #12 of 12 (permalink) Old 12-02-2006, 04:21 PM
jk69cat's Avatar
dameon, i havent forgot i got busy, ill take them apart tommarow and get a ship weight and price. justin
mn12 less!
jk69cat is offline
