Need a spolier installed - TCCoA Forums
post #1 of 6 (permalink) Old 03-02-2007, 03:39 PM Thread Starter
Me007gold's Avatar
Send a message via AIM to Me007gold
i picked up a spoiler at pick n pull last time was there and i need it installed. does any one know a place where i could get it done cheap in San Antonio?
Theres nothing better than having a lower roof line than a civic, and a longer wheelbase than a van.
Me007gold is offline
post #2 of 6 (permalink) Old 03-02-2007, 03:46 PM
Baby Huey
warmaster259's Avatar
Its really not that difficult. Does it need paint tho?
Jim
warmaster259 is offline
post #3 of 6 (permalink) Old 03-02-2007, 04:10 PM Thread Starter
Me007gold's Avatar
nope i got lucky and found one the same color as my car
post #4 of 6 (permalink) Old 03-02-2007, 04:16 PM
Traveler's Avatar
Then all you need is a tape measure, a drill, and a socket set. (and good nerves. I'd get real shakey drilling holes in perfectly good sheet metal)
Measure where you want it mounted (Measure at least three times). mark where the holes should be. then drill said holes. mount the spoiler (should be some type of sealer or gasket between the spoiler "legs" and the deck) and bolt it down.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 6 (permalink) Old 03-02-2007, 06:19 PM
Sig Nazi & Gallery Moderator
mrs.tbirdbrain's Avatar
You might want to put down some masking tape where you are going to are going to drill for a few reasons:
1. It makes it easier to mark where you want to drill
2. In case the drill slips, you won't scratch your paint
3. To keep the metal shards from the drill from swirling around and scratching your paint.
TBIRDBRAIN - PRESTON
YOU WILL NEVER BE FORGOTTEN
4/22/63 - 4/23/14
RIP JOEL BENDER
07/30/1979 - 03/26/2006
mrs.tbirdbrain is offline
post #6 of 6 (permalink) Old 03-02-2007, 07:33 PM
jnk3846's Avatar
You also need a small hole saw for your drill. Image Hosted by ImageShack.us
jnk3846 is offline
