Open House Installing PI Cams on June 9th - TCCoA Forums
post #1 of 23 (permalink) Old 06-08-2007, 10:51 AM Thread Starter
Banned
91bluecoupe's Avatar
Smile Open House Installing PI Cams on June 9th
TO ALL.....OPEN HOUSE at my house for installing PI cams in my car.
All help will be willingly accepted.
Beer and Pizza will be provided.
Come all who can help me with this.
RSVP by calling my cell or answering this post.
Cell# 321-961-3470
Jerry
91bluecoupe is offline
post #2 of 23 (permalink) Old 06-08-2007, 05:26 PM
Whining Intakes Rock
Al_Florida's Avatar
DAMN!!!! I might have to travel....
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 23 (permalink) Old 06-09-2007, 08:26 AM Thread Starter
Banned
Come on over. :-)
post #4 of 23 (permalink) Old 06-09-2007, 08:27 AM
thunderbirdlver's Avatar
Send a message via AIM to thunderbirdlver Send a message via Yahoo to thunderbirdlver
why cant you live closer?!?!?!
If your exhaust tip is larger than your cylinder bore, then you are a Ricer.
thunderbirdlver is offline
post #5 of 23 (permalink) Old 06-09-2007, 09:23 AM Thread Starter
Banned
I have had a couple people say that. Thanks anyway.
post #6 of 23 (permalink) Old 06-09-2007, 05:59 PM
Chapter Director Coordinator
jamesD's Avatar
how'd it go?
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #7 of 23 (permalink) Old 06-10-2007, 02:40 AM Thread Starter
Banned
half done hope to finish on Sunday.
Slow gone by myself.
post #8 of 23 (permalink) Old 06-11-2007, 08:06 AM Thread Starter
Banned
Not done yet,,,having problem understanding the timing marks on the cams and the chain.....I have the windsor cams...I think I know where I was going wrong but I hope to finish tonight...sure could use some help...
post #9 of 23 (permalink) Old 06-11-2007, 09:40 AM
nickmckinney's Avatar
See links in other thread, the full color pictures there are even with Windsor cams.
nickmckinney is offline
post #10 of 23 (permalink) Old 06-11-2007, 10:03 AM
Just a tad bit too far for me to make it down there. Hope you can get it done!!!
97qwikcat is offline
post #11 of 23 (permalink) Old 06-11-2007, 10:07 AM
Would love to help myself, but I don't know a thing about engine internals, and I'm having transmission and (now) brake issues with my own car. Good luck!
Iszi is offline
post #12 of 23 (permalink) Old 06-12-2007, 07:28 AM
jamesD's Avatar
do you see dots or dimples near a tooth on the cams? thats a timing mark
the keyway is actually the timing mark on the crank, we lined everything up with the keyway @ 6 0'clock i think and everything slides on using the keyway anyway
jamesD is offline
post #13 of 23 (permalink) Old 06-12-2007, 07:53 AM
James the crank keyway has to be at 10:30 or so, the timing mark needs to be at 6:00................
post #14 of 23 (permalink) Old 06-12-2007, 08:02 AM
jamesD's Avatar
ya.. thats it
http://www.modulardepot.com/?show=articlesdet&aid=32
makes life easier
jamesD is offline
post #15 of 23 (permalink) Old 06-13-2007, 09:24 AM Thread Starter
Banned
Smile
I got it thanks for all the help.....after timing it I turned the motor by hand it turned smooth without any interference.
Just one question though when I put the chain tensioner on the passenger side the cam did not put tension on the chain yet, was that because there was no oil in it as it was drained out when I compressed it to get it out. Will the chain tensioners automatically put the correct tension back on the chain?
Will finish up putting it back together tonight and fire it up...cross your fingers...I am a bit nervous.
Jerry
PS. JamesD I happen to love Airwolf. (ONE BADASS HELICOPTER)
post #16 of 23 (permalink) Old 06-13-2007, 11:40 AM
jamesD's Avatar
you turn it all the way around till the marks lined up again?
that takes a while
jamesD is offline
post #17 of 23 (permalink) Old 06-13-2007, 11:50 AM Thread Starter
Banned
Yeap and it take awhile to turn it by hand.
post #18 of 23 (permalink) Old 06-14-2007, 07:58 AM Thread Starter
Banned
I got it back together but I do not think the chain tensionors have moved enough as I have chain noise I drove it some this morning and it seems to be better but you can still here the rattle.
Any ideas?
Car is running great except for the rattle.
post #19 of 23 (permalink) Old 06-14-2007, 07:07 PM
jamesD's Avatar
ya.. that sux...
jamesD is offline
post #20 of 23 (permalink) Old 06-15-2007, 12:21 PM Thread Starter
Banned
I am going to take it all apart again(will be a pro soon) and look at the tensioners and guides and see what was not working. It maybe that the tensioners oil holes are clogged and that may fix it....but just alot of work to have to do again when I did not know to give them a good looking over the first time.
Car is running strong though...just have the chain noise.
post #21 of 23 (permalink) Old 06-15-2007, 03:29 PM
jamesD's Avatar
use a small blade screwdriver and just make sure the tensioners are fully extended
jamesD is offline
post #22 of 23 (permalink) Old 06-15-2007, 03:31 PM Thread Starter
Banned
I will believe me....do not want to do this again.
post #23 of 23 (permalink) Old 06-20-2007, 11:37 AM Thread Starter
Banned
Crap had another set back Monday night on the way home I blew the heater core bypass hose and sent antifreeze everywhere and the car got hot about 210 on the gauge...I replaced the hose and now I have a miss under laod and over 1K RPM...every time this 4.6 get water or any fluids on top of the motor this happens....do spark plug wires go back if antifreeze hits them? Or is it just the plugs got to hot and have to be replaced as I have done more times to this 4.6 than all the other cars I have owned.
