Project: Blow-me (pics) - TCCoA Forums
post #1 of 96 (permalink) Old 11-18-2005, 10:05 PM Thread Starter
Whining Intakes Rock
Al_Florida's Avatar
Notice: This article demonstrates what I have done to modify my car. Neither I nor TCCoA assume any responsibility if you use this article to try to modify your own car. You do so at your own risk.
Putting a used SVO on my 94 tbird on the cheap... cause I am.
So far the progress has been slow but steady.
Parts removed include the 94 fuel lines, upper and lower intake, throttle body, EGR tube, FEAD belt, alternator, upper radiator hose, drivers side coil pack. After freeing the power steering resv you remove the drivers side coil/resv mount. From this pile, you will reuse the alternator and coil pack. The rest is scrap to clutter your garage for a few months.
I dropped the exhaust and remove the passenger side cowl cover to give me more access.
Trans is the empty case from the original 94 I busted.
The Egr - knuckle buster but came out in one piece
Highly recommend hitting the EGR fittings with PB Blaster the day before. A couple of light taps on the fitting before you take a wrench to it and it should come off fairly easy. Watch your knuckles when it does finally give.
Engine compartment:
I've read some posts where people claim they have coolant leaking out of the converter inspection plate. If you look in the engine valley, right below the numbers "55783" there is a plug. This leads to the bellhousing of the trans. When your intake cracks, it's possible for coolant to leak through this plug. I guess at one time the plug was pliable rubber. Now it is almost solid like plastic.
96 fuel line installed. The 94/95 fuel rail has the fuel line connections and FPR in the same area that the intake of the SVO needs to be. When you change to the 96/97 fuel rail, you also need to change the fuel lines. Although I've seen one person that just bent the 94/95 lines to fit.
and mess from coolant.
Good news on the coolant... it ran to the end of my driveway and killed the grass running across it so now I don't have to hit that with round-up.
Injectors that came with this were painted or the paint was peeling off. Uck... Just has to come all the way off now. Gumout rocks.
Will probably repaint them black.
Cleaned, tapped and ready for assembly. The red circle shows where you drill and tap for the Lightning Air Charge Temp sensor. You drill a hole using a 37/64 bit. The tap is 3/8 NPT. No one around me carried the bit. Home Depot, Lowes, Ace, Tru Value only had up to 1/2". Forget Sears (Kmart) the store by me is useless now. I ordered a bit from Grainger. Tru Value had the 3/8 NPT tap surprisingly.
The reason for tapping for the ACT:
The SVO does not have an intercooler. Nor is there any practical way to add one. You will need to have your computer retuned and your tuner can set it up to pull timing based on the intake temp. The ACT above now sits AFTER the charger in the compressed heated air.
to be continued...
# 0 rows returned
# drop table users;_
Last edited by Al_Florida; 04-12-2008 at 07:18 AM. Reason: Changing location of pics.
Al_Florida is offline
post #2 of 96 (permalink) Old 11-18-2005, 10:07 PM
VicRattlehead's Avatar
looks good so far.
reds are what 24#?
CMP Drag Racing
VicRattlehead is offline
post #3 of 96 (permalink) Old 11-18-2005, 10:08 PM Thread Starter
Al_Florida's Avatar
30#
# 0 rows returned
post #4 of 96 (permalink) Old 11-18-2005, 10:33 PM Thread Starter
Al_Florida's Avatar
Oh and side note... I washed all the coolant away so no animals would drink it.
# 0 rows returned
post #5 of 96 (permalink) Old 11-19-2005, 03:07 PM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Hey, those fuel lines look familiar Lookin' good so far!
Aaron K. is offline
post #6 of 96 (permalink) Old 11-19-2005, 04:14 PM Thread Starter
Al_Florida's Avatar
More progress and a $#@% set back.
Stock (and filthy) 96 fuel rail.
Moding the rail.
Molded Fuel line supplied in the SVO install kit.
Checking the pressure regulator. It was loose and would have made a nice mess.
O-rings look good. Clean it up and put it back on and tighten it.
Modified rail. All cleaned up and ready to go on.
Better check the thermostat.
O-ring was stuck in there and fused to the old thermostat.
Old vs New
SVO with rail and injectors installed:
Damn! Need a new alternator. Plastic on the back just disintegrated.
Off to go get some beer...
# 0 rows returned
post #7 of 96 (permalink) Old 11-19-2005, 04:27 PM
Talking
Thank you!!
ShadsWife is offline
post #8 of 96 (permalink) Old 11-19-2005, 04:28 PM
Man thats gonna be so cool, Cant wait to see when its done...
DMcBrideBoston is offline
post #9 of 96 (permalink) Old 11-19-2005, 04:59 PM Thread Starter
Al_Florida's Avatar
I'll get a vid of the start but have to find a way to get it onto the computer. Might have to break down and buy a firewire card.
# 0 rows returned
post #10 of 96 (permalink) Old 11-19-2005, 05:11 PM
Who is John Galt?
Sounds like you've earned it.
"Won't work, can't be done"
cougar_guy04 is offline
post #11 of 96 (permalink) Old 11-20-2005, 03:07 PM Thread Starter
Al_Florida's Avatar
Next day... The old 2 steps forward, 3 steps back routine.
SVO on engine. This part was a bit of a beotch. Easier with two people but if you climb up in your engine you can manage yourself. I did and I'm an old man.
( I like how Ford conveniently placed a tool holder above the radiator. )
Plug wires run, New coil pack bracket and LH coil pack installed. Alternator mocked on. Be careful you don't pinch the plug wires under the SVO snout. Easy to do.
I was missing the extended heater hose that was supposed to come with the kit. Remember I bought this used. The heater hose runs from the outlet just below the thermostat housing to the inlet on the heater core. Apparently this hose is not available separate so if you didn't get one or yours breaks, you're stuck making one from straight hose and fittings.
That was the good stuff.
Now the questionable.
Pics of passenger side rear of SVO.
Maybe this is normal? Will have to ask some experts.
Now the bad.
First is the lovely 94 engine harness:
That's not gonna work. Have to break the plastic wire guide off and rewrap the harness.
1 wire plug + 2 wire sensor = NFG. Have to replace that sensor.
Round peg into a square hole? Nope. Need to get another pigtail or replace the sensor from your old intake.
... That's all for today ...
# 0 rows returned
Last edited by Al_Florida; 04-12-2008 at 07:28 AM. Reason: Changing location of pics.
post #12 of 96 (permalink) Old 11-20-2005, 03:47 PM
02 Explorer Pioneer
timb's Avatar
Don't worry it's a dry hole. It freaked me out when I did my install too
Birdless
timb is offline
post #13 of 96 (permalink) Old 11-20-2005, 03:53 PM Thread Starter
Al_Florida's Avatar
Thanks!
# 0 rows returned
post #14 of 96 (permalink) Old 11-20-2005, 06:24 PM
sorry off topic...does that blower make a lot of noise(whine)?
weswing04 is offline
post #15 of 96 (permalink) Old 11-20-2005, 06:50 PM Thread Starter
Al_Florida's Avatar
I hope its obnoxious.
Don't think it is though. Have to ask Tim or RobP.
# 0 rows returned
post #16 of 96 (permalink) Old 11-20-2005, 07:36 PM
i want an SVO blower for my car.....lucky
94V8Thunderbird is offline
post #17 of 96 (permalink) Old 11-21-2005, 08:03 AM
02 Explorer Pioneer
timb's Avatar
Under normal driving conditions you would never know it's there but when you romp on it absolutely you can hear it spool up. To use a phrase I got from A-train it sounds like an atomic vacuum cleaner.
Birdless
timb is offline
post #18 of 96 (permalink) Old 11-23-2005, 02:33 PM Thread Starter
Al_Florida's Avatar
Will have more pics after Turkey day. Have a Happy Thanksgiving everyone.
# 0 rows returned
post #19 of 96 (permalink) Old 11-24-2005, 06:53 AM
Oh, now that is cool. Good job
unclenick is offline
post #20 of 96 (permalink) Old 11-26-2005, 03:14 PM Thread Starter
Al_Florida's Avatar
Saturday: more progress
Repaired the alternator, fixed up the intake, tightened up the coil bracket, power steering resv and alternator. Marked some wires. Replaced some temp sensors. Altered the rad hose. I think it's still a bit too long.
Thanks to tbirdbrain and his local connections, I was able to get a replacement regulator for the alternator. Saved me some cash.
Putting on the radiator hose. Had to trim some off one end. Thinking it could use some more at the other end. Looks like it's kinked too much in the middle
Engine so far. Minus the radiator hose, sensors replaced.
and still had time to cut the grass.
# 0 rows returned
post #21 of 96 (permalink) Old 11-26-2005, 03:30 PM
JustinH's Avatar
goodstuff al!
JustinH is offline
post #22 of 96 (permalink) Old 11-27-2005, 10:27 AM Thread Starter
Al_Florida's Avatar
Not that much left to do.
Throttle and cruise cables, vacuum hoses, wiring, egr tube, have to make a bracket for egr related stuff, put the eec back in, get a fire extinguisher ready heh. The egr is shut off in the computer. Does anyone know if the computer still expects to find the DPFE and EVR? If not I won't even bother putting them back on.
Next pic will probably be of the completed engine and then I'll take a video of the start. Hopefully before Thursday and then I can get some runs in at Bradenton if it looks ok.
# 0 rows returned
post #23 of 96 (permalink) Old 11-28-2005, 10:01 AM
02 Explorer Pioneer
timb's Avatar
If it is disabled in the EEC it shouldn't look for the DPFE not sure on the EVR
Birdless
timb is offline
post #24 of 96 (permalink) Old 11-28-2005, 10:23 AM Thread Starter
Al_Florida's Avatar
Ok thanks. I put the DPFE in with the EGR tube but I don't have a bracket for the EVR. I can make one unless Dan has it cheap.
Tim,
In this pic, the vacuum hose outlined in red, did you extend it and plug it into the large nipple on the back of the svo? Mines too short to make the turn and I don't think I got a proper vacuum harness. The vacuum harness I did get is damaged. Trying to see if I can get a replacement from Dan.
If I remember that's an 11/32" hose.
# 0 rows returned
post #25 of 96 (permalink) Old 11-28-2005, 10:35 AM
02 Explorer Pioneer
timb's Avatar
Yes just extend it to the rear of the SVO. There is nothing real special about the harness especially if you are leaving the EGR off. You should be able to make your own with a little hose and a couple of T connectors. Without the EGR all you will need to run is a hose from the nipple on top of the SVO to your FPR and then a second line from the rear to the bypass. Everything else is just normal PCV etc
Birdless
timb is offline
post #26 of 96 (permalink) Old 11-30-2005, 01:14 PM Thread Starter
Al_Florida's Avatar
Pasta day
Taking a break so I figured I'd snap a shot of the mess I made.
# 0 rows returned
post #27 of 96 (permalink) Old 12-01-2005, 11:00 AM
02 Explorer Pioneer
timb's Avatar
That's a pretty advanced mess
Birdless
timb is offline
post #28 of 96 (permalink) Old 12-01-2005, 11:23 AM Thread Starter
Al_Florida's Avatar
Yeah no kiddin.
This is where I left off yesterday:
One more sensor to wire and then I can wrap the whole thing and start on the hoses.
# 0 rows returned
post #29 of 96 (permalink) Old 12-01-2005, 01:19 PM
95RoaringCougar's Avatar
Send a message via AIM to 95RoaringCougar
man how did i miss this thread??? thats awesome....i cant wait for a vid....
brought the cat from the dead...
95RoaringCougar is offline
post #30 of 96 (permalink) Old 12-01-2005, 09:22 PM
Are all those wires inside the harness?
Oh God.....
