i smell gas - TCCoA Forums
post #1 of 8 (permalink) Old 01-01-2002, 08:00 PM Thread Starter
ogbird95's Avatar
sorry guys should have been clearer, and yes i did mean I can smell gas after i fill up, but not right after rather the next morning.
ogbird95 is offline
post #2 of 8 (permalink) Old 02-01-2010, 01:00 PM Thread Starter
ogbird95's Avatar
i smell gas
i smell gas when i fill up could this be a serious problem?
ogbird95 is offline
post #3 of 8 (permalink) Old 02-01-2010, 01:03 PM
wow, can you make the question have a little more detail?
Cause I smell gas too when I fill up......it comes out of the nozzle from the pump.
post #4 of 8 (permalink) Old 02-01-2010, 01:16 PM
Mgino96tbird46's Avatar
Ummm, yeah. That's normal. The vapors do travel. However, more detail about when and where you smell gasoline would shed some light on the situation. Not trying to be a nag, just trying to better understand your situation.
Mgino96tbird46 is offline
post #5 of 8 (permalink) Old 02-01-2010, 01:29 PM
LOL Thank you sir for the smile
post #6 of 8 (permalink) Old 02-01-2010, 01:54 PM
machausta's Avatar
I'm going to turn on my psychic powers for a moment to divine that you mean after you fill up the car you smell gas inside for a few minutes.
If this is the case, I would check the tank to make sure it isn't leaking, and the filler neck to be sure it isn't being stopped by something. I found the silver inner seal from a bottle of fuel injector cleaner in mine, and it was causing the pump to just click off every few seconds at certain filling stations.
/psychic mode off
2011 Dodge Durango Crew 5.7L HEMI
2001 Volkswagen Beetle GLX 1.8T
machausta is offline
post #7 of 8 (permalink) Old 02-01-2010, 02:47 PM
94t-birdlx's Avatar
Send a message via AIM to 94t-birdlx Send a message via MSN to 94t-birdlx
Sorry guys, my bad.... Taco Bell for lunch.
"Technical skill is mastery of complexity while creativity is mastery of simplicity."
94t-birdlx is offline
post #8 of 8 (permalink) Old 02-01-2010, 04:42 PM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
