Dirty Fuel Injectors! - TCCoA Forums
post #1 of 3 (permalink) Old 07-15-2002, 03:51 PM Thread Starter
Post Dirty Fuel Injectors!
The two front fuel injectors (left and right) in my 4.6L
are dirty with black engine oil. Ford just replaced my
intake manifold a month ago (the orginal manifold
was actually OK.) Any clues? I can't think why
oil goes to injectors, and yes just two of them.
I can smell something from there after a relatively
long drive. Any input appreciated!
bbird is offline
post #2 of 3 (permalink) Old 07-15-2002, 04:49 PM
Mushroom Stamp Layer
seabass's Avatar
you sure oil didn't just get spilled on them? Do you have a picture of them?
Seabass
seabass is offline
post #3 of 3 (permalink) Old 07-15-2002, 10:52 PM
If the oil was on the outside of the injector tips, I wouldn't worry about the injectors unless you were getting trouble codes. I would worry about where the oil was coming from.
If oil were spilled so it got into the injector O-ring area, it might get sucked past the seal. Some people oil up the seals and bores before installing injectors - less wear on the O-rings.
bill_s is offline
