reading abs codes - TCCoA Forums
post #1 of 8 (permalink) Old 01-01-2002, 02:36 PM Thread Starter
white 97 lx's Avatar
So now my question is how do I test the sensor to make sure that's what is setting the code 32? Or is a bad sensor the only thing it can be?
white 97 lx is offline
post #2 of 8 (permalink) Old 06-09-2010, 12:40 AM Thread Starter
reading abs codes
Who can read abs codes for me? Autozone? O'Reilly's? Light is on and don't know where to start. I've visually inspected the sensors and relay. Now what to do next? I assume have the codes read but don't know where I can get this done
post #3 of 8 (permalink) Old 06-09-2010, 12:42 AM
Check out the sticky at the top of the brake section for your answer.
post #4 of 8 (permalink) Old 06-09-2010, 06:39 AM Thread Starter
awesome, why wouldn't that come up when I searched abs codes? Now I just need to find the diagnostic connector for the abs.........
post #5 of 8 (permalink) Old 06-09-2010, 07:21 AM Thread Starter
found it.......thanks
post #6 of 8 (permalink) Old 06-09-2010, 11:59 PM Thread Starter
Okay so tonight I jumped the 4 and 5 pins and got a 32, right front wheel sensor. Not knowing for sure if it was right side from in the car or front I unplugged what I thought would be the left sensor (driver side). Check code again and still have just a 32. So now I'm thinking that that driver side must be right side and crawl under and unplug the pass side sensor and check again......still only getting a 32 code, what gives? Both sensors to the front wheels were disconnected and I only flashed a right front sensor code?
post #7 of 8 (permalink) Old 06-10-2010, 01:23 AM
The code won't set immediately. How long did you wait before you unplugged the sensors and read the codes?
post #8 of 8 (permalink) Old 06-10-2010, 06:33 AM Thread Starter
Only a minute or two. I thought the system scanned itself immediately upon startup?
