4.6 radiator upgrade - TCCoA Forums
post #1 of 10 (permalink) Old 01-02-2002, 01:12 AM Thread Starter
irvin's Avatar
Question 4.6 radiator upgrade
are there any radiators out there that will look factory stock but have a 2 row
core for a little more capacity in a 96 4.6 cougar or tbird?--irv
96 XR7-36000 miles- pretty much mint
4.6--ZU blue, all leather,autolamp.auto temp
r. power seat added .sold in july-14
bought back-dec,14 left w/25000.came
back w/36000.
irvin is offline
post #2 of 10 (permalink) Old 01-02-2002, 03:30 AM Thread Starter
irvin's Avatar
the post locations get weirder all the time
back w/36000.
irvin is offline
post #3 of 10 (permalink) Old 06-16-2010, 06:42 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
Well its been 8 years, but since you posted this the 03 Cobra radiator swap has become pretty popular, but it is an all-aluminum radiator. The stock one in your bird has plastic tanks.
-Rob
-Rob
Rob is offline
post #4 of 10 (permalink) Old 06-16-2010, 06:51 AM Thread Starter
irvin's Avatar
i was reading that one but i wanted to retain the stock look. guess
ill leave it alone. it doesnt overheat.just looking for options
back w/36000.
irvin is offline
post #5 of 10 (permalink) Old 06-16-2010, 12:30 PM
if you have the cash griffen is the way to go.
post #6 of 10 (permalink) Old 06-16-2010, 01:55 PM
The 03 cobra rad is about as stock looking as your going to get and be an upgrade. Unless you have an MN12 enthusiast looking under your hood, no one will look twice.
post #7 of 10 (permalink) Old 06-16-2010, 04:05 PM
Bump to a 8 yr old thread!
I bought a radiator from radiator classic that was selling them on ebay. Great price and a decent unit. All aluminum makes it worth the trouble, the fan didn't fit exactly right I had to trim it a alittle and bend some brackets.
post #8 of 10 (permalink) Old 06-16-2010, 07:17 PM
Also note that if you go with the 03 Cobra rad. (not sure on the one Alan mentioned) that you MUST get an external transmission cooler, as the Cobra rad. does not have the intregal heat-exchanger that the stock one does.
I have a Cobra rad in my 95, and it works great. Fits ok w/ some modifying of the stock mounts (flip the top ones upside down). Downside is it won't hold up to running over a deer
Personally, I would install an external cooler anyways, just to help that 4R live a longer life. Otherwise you may be talking to Alan about more than a rad. in the near future, lol...
Jay
FordMan77 is offline
post #9 of 10 (permalink) Old 06-16-2010, 09:46 PM
Cobra Radiator
I also have a 1995 Ford Thunderbird with a 2003 Cobra Radiator in it. I put the original fan/shroud back on with a large tranny cooler strapped to the radiator (the Cobra has no internal automatic tranny cooler). When you look under the hood, you cannot tell it is not stock. You can't see the cooler because of the radiator support and condenser in front. The only way you can tell is the tanks are not plastic and the radiator is slightly wider (and taller) and I had to cut a half inch corner from the battery tray for clearance, but that is not noticable by the untrained eye.
I honestly believe the only way you could tell is if you put a stock '95 next to mine and LOOKED for the differences they are so slight. BTW, this was a required upgrade for me as my car would not stop overheating in the 100* plus heat here in the summer.
post #10 of 10 (permalink) Old 06-17-2010, 12:11 AM
CrystalPistol's Avatar
98 degrees, I made a stop, wife and dog in car, I let it run with AC on while I ran into store. Told wife to watch Scan Gague II temp, it ran up to 202 once, stayed nearer 200 while ore for near 30 minutes.
Runs 196-198 going down the roadway.
Stock '95 4,6.
CrystalPistol is offline
