help with oil leaks - TCCoA Forums
post #1 of 11 (permalink) Old 11-06-2010, 01:18 PM Thread Starter
help with oil leaks
what are the common places for oil leaks?leaking about a quart every couple of days...looks like it may be below the exhaust but above oil flter?to much of a mess under there i cant really tell.
air silencer removed, dorman intake manifold,clear corner lights,psp with psp windshield mount,blue led moded gauge cluster.
lozer81 is offline
post #2 of 11 (permalink) Old 11-06-2010, 01:55 PM
sousa632's Avatar
My guess would be the oil filter adapter gasket if it's not the filter itself. Someone had a recent topic about it.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #3 of 11 (permalink) Old 11-06-2010, 02:44 PM Thread Starter
is that the same thing as a oil filter cover gasket?
lozer81 is offline
post #4 of 11 (permalink) Old 11-06-2010, 05:44 PM
dDUBb's Avatar
Its the gasket that goes between the engine Block, and the Adapter piece for the Coolant elbow / Oil filter adapter. Common problem for 4.6 motors.
dDUBb is offline
post #5 of 11 (permalink) Old 11-06-2010, 05:48 PM Thread Starter
thanks guys...im gonna work on it tomorrow to see if thats the case
lozer81 is offline
post #6 of 11 (permalink) Old 11-06-2010, 06:42 PM
sousa632's Avatar
FYI, here's a topic showing you what to look for and what typically leaks..
http://forums.tccoa.com/showthread.p...er+leak&page=2
John
1996 TBird LX 4.6
sousa632 is offline
post #7 of 11 (permalink) Old 12-18-2010, 04:39 PM
lozer if you would, could u put a pic of what this looks like cause i think mine is leaking from the same place thank you id really appreciate it
Travis_Holt is offline
post #8 of 11 (permalink) Old 12-19-2010, 03:17 AM
CrystalPistol's Avatar
Travis, check out the thread posted above you. I'll practically guarantee that's what his leak is from above the filter and below the exhaust.
My gasket was cheaper and faster from NAPA than local Ford dealer.
CrystalPistol is offline
post #9 of 11 (permalink) Old 12-19-2010, 09:11 AM Thread Starter
hey guys just a little update, i replaced this gasket, at first the job seemed impossable but after workin on it it actually wasnt bad at all, took me about an hour.
this gasket was indeed the problem, after replacing it the leaking stopped which is awesome cause it was pretty much pouring out a quart or two every couple of days.
yes it was leakin from above the oil filter but just below the exhaust, thanks to everyone here i have now solved this issue, ive read this is a very common thing to happen to 4.6's.
well worth the fix not to mention the drive way is looking much better lol!
also had to put in new anti-freeze,oil and oil filter to do this job. the oil filter adapter gasket was like 6 bucks at advancedauto.
lozer81 is offline
post #10 of 11 (permalink) Old 12-19-2010, 03:13 PM
Seems intimidating because of the location, but the filter is still the most difficult thing to remove from that area lol
post #11 of 11 (permalink) Old 12-19-2010, 03:23 PM
Faster than Porkchop
cjchevez's Avatar
Time for a oil filer relocation adapter!
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
