Charging Problem with 97 Cougar Sport. "List of parts already replaced" - TCCoA Forums
post #1 of 14 (permalink) Old 11-18-2010, 05:41 PM Thread Starter
RCReevesPhotography's Avatar
Symptoms: Not charging, Keyless Entry wont work.
Have replaced: Alternator, MegaFuse and Battery.
Am: Out of Ideas.
"Dream like you will live forever, live like you will die today"
RCReevesPhotography is offline
post #2 of 14 (permalink) Old 11-18-2010, 05:58 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Lets: move this to General Tech since it's not an engine issue
guitar maestro is offline
post #3 of 14 (permalink) Old 11-18-2010, 06:00 PM Thread Starter
Okay, sounds good.
post #4 of 14 (permalink) Old 11-18-2010, 06:22 PM
did this happen out of the blue, or were you tinkering with some wiring? I do know for a fact that there is a turn-on wire that if not connected to switched 12V power, the alternator won't do squat
post #5 of 14 (permalink) Old 11-18-2010, 06:43 PM Thread Starter
My wife was driving it home from work last night and it more or less died in the middle of the street.
Wiring has been done in the past but that was two or three years ago.
post #6 of 14 (permalink) Old 11-18-2010, 07:20 PM
http://forums.tccoa.com/showpost.php...0&postcount=10
post #7 of 14 (permalink) Old 11-18-2010, 07:54 PM
post #8 of 14 (permalink) Old 11-18-2010, 07:58 PM Thread Starter
I'll check that and see whats going on with it.
post #9 of 14 (permalink) Old 11-18-2010, 11:48 PM
By mega fuse do you mean the 15 amp "generator" fuse under the hood?
1995 Thunderbird 4.6
Clear corners, HID's, 2 15" Kickers, CAI, 2 1/2 Dual exhaust w/ x-pipe original 40s, 3.27 TL
sprite is offline
post #10 of 14 (permalink) Old 11-19-2010, 12:05 AM
No, we mean the mega fuse.
It's that big honker (125A?) that's on the front of the fuse box by the battery.
RalphP is online now
post #11 of 14 (permalink) Old 11-19-2010, 09:05 AM
I had this same no charging problem a couple months ago. It wound up being a 15 amp fuse under the hood labeled "generator".
http://forums.tccoa.com/showthread.p...d+satc%2Fvolts
sprite is offline
post #12 of 14 (permalink) Old 11-19-2010, 04:35 PM Thread Starter
I looked inside my underhood fuse box and don't see any 15amp fuses labeled "generator" Is the fuse in the box?
EDIT On my car fuse number 11 is labeled Radio. Now I get it...
EDIT II, I checked/replaced fuse 11 and it's still not charging.
post #13 of 14 (permalink) Old 11-19-2010, 10:43 PM
I had to go and check just now, but yes, the fuse I was talkiing about is 11 in the high current box under the hood. Sucks that isnt the problem, hell I would of bet 5 bucks it was.
sprite is offline
post #14 of 14 (permalink) Old 11-20-2010, 12:05 PM
It won't charge if the dash circuit is in tact and working. When you are in Key on/Engine off, does the battery light illuminate in the upper left pod of the IP? I think that there is a resistor that is in parallel with the light, so there might be an issue there.
I drove my 89 without the IP for a year or so, I soldered a resistor in place of the IP so that it would charge (actually I think it was a light bulb and resistor, I can't find it now).
Bangster is offline
