Vibration/Locks don't work - TCCoA Forums
post #1 of 15 (permalink) Old 11-22-2010, 12:08 PM Thread Starter
Sixx23's Avatar
Send a message via AIM to Sixx23
Hey guys, last Summer I began to work on my Uncle's '97 Thunderbird. It had been sitting in his backyard for about 3 years and I had taken notice of it. I asked him why it wasn't running, etc. Well after some diagnosing, I had figured out the fuel pump was bad. Got a new fuel pump, and 11 hours of work later (first time doing the job, and I'm a nooby 17-year-old), it starts right up! It's been about six months since then, and we've ripped the seats out, given it a good cleaning, replaced all four tires, plugs, wires, and all the fluids, except for oil (Waiting for time to get it done). It runs decently now, but not up to par. When you are accelerating very slowly, say out of a driveway, it'll get a pretty bad vibration. But other than that, there is none what-so-ever. Could this be linked to the oil needing changing?
Also, after doing the seats, the lock/unlock stopped working. Whenever you hit unlock, all the lights in the car go dim, and when you hit lock nothing happens. We're not exactly sure of where to begin, but may check the wires that run under the driver side seat.
Thanks.
Sixx23 is offline
post #2 of 15 (permalink) Old 11-22-2010, 02:22 PM
Earl's Avatar
Not sure about the lights/locks, but as for the vibration upon accel. I would think maybe it's trans / TC shudder...how is the trans fluid? A fluid/filter change will probably do wonders on that trans...and change the oil....3+ years of sitting is bad for fluids....how many miles on that one anyway?
Earl is offline
post #3 of 15 (permalink) Old 11-22-2010, 02:34 PM Thread Starter
Sixx23's Avatar
Alright. The trans fluid could probably use changing as well. My Uncle actually HAD to drive the car to work today.. It's not ideal on the oil, but there was nothing he could do about it. He seems to think the transmission could probably use some fluid, so I'll look into it.
122k, A little under what it should be at.
'97 Thunderbird LX - 4.6L
Sixx23 is offline
post #4 of 15 (permalink) Old 11-23-2010, 05:06 AM
J. Arkayman's Avatar
Changing the transmission fluid made a world of difference in my car. Just make sure to use the proper fluid.
And
Change the oil!
J. Arkayman is offline
post #5 of 15 (permalink) Old 11-23-2010, 08:22 AM
sousa632's Avatar
I agree with changing the trans fluid. Make sure that you drain the torque converter out as well and ONLY use Mercon V fluid. It will take about 13qts to fill if you drain the converter as well.
Another thing to do it clean the MAF. Get the CRC MAF cleaner and do it with that. Search here and there are writeups on how to do it if you are not sure. One more thing...... check for vacuum leaks, especially the elbow at the back of the plentum and the hose along the passanger side wheel well.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #6 of 15 (permalink) Old 11-23-2010, 08:52 PM Thread Starter
Sixx23's Avatar
Added some transmission fluid.. Thing was almost dry. Helped quite a bit...
Well, my aunt went and took it to the gas station to get some gas.. As soon as it was done fueling up, gas started pouring out. Uncle had to drive it home, and it left a trail all the way home. Checked all the fuel hoses and could find nothing that was disconnected..
Sixx23 is offline
post #7 of 15 (permalink) Old 11-23-2010, 09:20 PM
Earl's Avatar
sometimes that can happen if the person filling it up continues to try to top it off well beyond it's capacity...20 gallons in an 18 gallon tank, ya know
Earl is offline
post #8 of 15 (permalink) Old 11-23-2010, 09:24 PM Thread Starter
Sixx23's Avatar
Yeah, I understand..
Would that cause a trail for at least a mile though?
Sixx23 is offline
post #9 of 15 (permalink) Old 11-25-2010, 11:16 PM
Nitemare's Avatar
You checked the hoses, but did you check the filler neck?
Needs more stall.
Nitemare is offline
post #10 of 15 (permalink) Old 11-26-2010, 02:07 PM Thread Starter
Sixx23's Avatar
Yes, and that's also fine.
Sixx23 is offline
post #11 of 15 (permalink) Old 11-26-2010, 03:38 PM
Earl's Avatar
Well, how is the fuel consumption of the vehicle....50 miles to a tank?
Earl is offline
post #12 of 15 (permalink) Old 11-27-2010, 08:46 PM Thread Starter
Sixx23's Avatar
It hasn't even had the chance to use up a whole tank. This was the first time putting a whole tank of gas in it, in over 3 years.
Sixx23 is offline
post #13 of 15 (permalink) Old 11-27-2010, 09:18 PM
Earl's Avatar
Just thinking maybe there could be a leak in the tank or in one or more of the fuel lines
Earl is offline
post #14 of 15 (permalink) Old 11-27-2010, 09:23 PM
You sure you got the o-ring on top properly back in place when you put it back on?
a black car.
Sophosis is offline
post #15 of 15 (permalink) Old 11-28-2010, 12:28 AM Thread Starter
Sixx23's Avatar
Definitely need to check that.
It was a PAIN when putting the new one on it.
It was about 5x tighter of a fit when we put the new O-ring on.
Sixx23 is offline
