MAF attachment - TCCoA Forums
post #1 of 8 (permalink) Old 11-29-2010, 02:40 PM Thread Starter
TRex94's Avatar
MAF attachment
Hi Everyone, would anybody know if a Ford Lightning 80 or 90mm is a direct plug-in to a 94 Bird 4.6l or is there an adapter or maf harness that has to be bought?
TRex94 is offline
post #2 of 8 (permalink) Old 11-29-2010, 03:05 PM
You'll need to cut and splice the connector off a 96+ to use them, the gt maf you would a 02-04 mustang connector if you want to use the integrated iat.
post #3 of 8 (permalink) Old 11-29-2010, 03:08 PM
Just a reminder that you can't use a MAF sensor or MAF sensor housing that isn't stock without getting a tune. To answer the question, the MAF harness changed beginning in 96 so you would either need the pigtail or an adapter harness. The 02-04 GT MAFs have an integrated IAT sensor which requires you to add the pins as well.
post #4 of 8 (permalink) Old 11-29-2010, 03:33 PM Thread Starter
TRex94's Avatar
Maf
I need a MAF for a Mark VIII engine recently installed in my 94 Bird, any suggestions 80,85, or 90mm, yes the computer will be tuned to accomadate the Mark engine.
TRex94 is offline
post #5 of 8 (permalink) Old 11-29-2010, 03:39 PM
Moderator & Teksid Whore
guitar maestro's Avatar
no such thing as an 85mm oem maf...it's either 80mm (mustang gt's and some other passenger cars) or 90mm (lightning and 03/04 cobras)
the only cons about the 90mm maf is that you have to reuse your existing IAT sensor and plumb it in somewhere.....also, with either one, you need to decide what to do for an airbox, or if you plan to run an open filter inside the engine bay
guitar maestro is offline
post #6 of 8 (permalink) Old 11-29-2010, 03:48 PM Thread Starter
TRex94's Avatar
Thanks Maestro good info.
TRex94 is offline
post #7 of 8 (permalink) Old 11-29-2010, 04:20 PM
VicRattlehead's Avatar
lightning had an 80mm at one point.
CMP Drag Racing
VicRattlehead is offline
post #8 of 8 (permalink) Old 11-29-2010, 05:12 PM
Quite true, but the 02 gt maf is superior overall IIRC
