Slammed into curb, now wheel wobbles - TCCoA Forums
post #1 of 10 (permalink) Old 12-06-2010, 11:36 AM Thread Starter
97 mustang gt
I was making a nearly blind left turn out of a parking lot and floored it to keep from getting hit. Unfortunately all those go fast mods I made asserted themselves, I fishtailed, and slammed my right rear wheel HARD into the curb. It totally demolished the wheel and peeled off about a 2 foot long section of it. I replaced the wheel and now it wobbles. What did I bend to make it do that? The axle? Will I need a whole new rear end or just an axle on that side?
geaux is offline
post #2 of 10 (permalink) Old 12-06-2010, 11:45 AM
The axle itself is definitely bent. Those bend very easily. Replace the axle first, and then see where you are at. The rear housing is probably alright, it takes a lot to bend those.
post #3 of 10 (permalink) Old 12-06-2010, 11:51 AM Thread Starter
Thanks Mikey. How involved is replacing an axle?
geaux is offline
post #4 of 10 (permalink) Old 12-06-2010, 12:20 PM
Basically: Remove the differential cover, remove the bolt holding in the center shaft, remove the shaft, slide the axle inward, remove the "C" Clip, slide the axle out.
Pretty easy, just real messy. (Those are just the cliff notes).
69 F100 LWB w/460 Engine
post #5 of 10 (permalink) Old 12-06-2010, 12:36 PM
Yes chances are the axle is bent. I have a 2000GT and the stock axles are super weak. I snaped one launching on the street with DR's. I went with a Cobra carrier, 31spline moser axles. About $700 in parts. Well worth it, you wont break them. The biggest thing is getting the ABS sensors pressed off the old axles with out breakin them. They should press on the new axles fairly easy..
Good luck.
1994 Ford Thunderbird LX 4.6L - Junked
1997 Ford Thunderbird LX 4.6L - SOLD
1999 Merc Grand Marquis - DD
2003 Ford Expedition XLT 5.4L - Chicks Tank
2000 Ford Mustang GT 4.6L - Racecar
GT_any is offline
post #6 of 10 (permalink) Old 12-06-2010, 12:39 PM
Unless you launching at 4500-5000RPM's with a Slick and a 4.30 gear. Its pretty easy to torque it out of alignment
But sliding into a curb... it will prolly take that without a problem.
GT_any is offline
post #7 of 10 (permalink) Old 12-06-2010, 01:25 PM Thread Starter
GT_any it didn't slide into a curb, I walloped it. I wish I had taken a pic of the rim. Pretzeled it up into abstract art.
geaux is offline
post #8 of 10 (permalink) Old 12-06-2010, 01:40 PM
Nitemare's Avatar
Check your rear arms too, the axle is also probably pushed sideways.
Needs more stall.
Nitemare is offline
post #9 of 10 (permalink) Old 12-06-2010, 01:57 PM
True story! If you need stock upper and lower control arms. I have a stock set i'll sell you off my 2000GT. Im going to be upgrading sometime before spring.
GT_any is offline
post #10 of 10 (permalink) Old 12-06-2010, 02:51 PM
CrystalPistol's Avatar
Budy of mine did same thing back in the '70s in his '74 Mustang Mach1 .... which had a stock V-6. He did it in the rain, didn't even scuff tire sidewall, but bent axle.
Well ..... maybe it wasn't "the same thing" he done, but it was close?
geaux, .... as hard as you hit, you need to get her on a lift and carefull examine all control arms and the mounting points at the car's frame as well, and after replacing the axle shaft that is definately bent .... put a point (a thumb tack is good) on both the left rear and right rear tire's tread. Rotate the tires to where the point to straight back, meassure between them, then rotate to bottom and meassure again, and then rotate so straight to front of car and meassure again while on the lift.
All three distances should be same. If all three aren't same, housing is tweaked .... or just "bent". They don't have to be exactly same but within 1/8" would be good.
Remove thumb tacks.
CrystalPistol is offline
