How to take out this panel? - TCCoA Forums
post #1 of 15 (permalink) Old 12-19-2010, 02:29 PM Thread Starter
stingu's Avatar
Hi guys
How to take out this panel (just the one with fan controls on it):
I need to replace one bulb and I dont want to take out whole dash if i dont have to
stingu is offline
post #2 of 15 (permalink) Old 12-19-2010, 02:35 PM
dDUBb's Avatar
YOu need to remove the center console top, and the dash surround. There are bolts behind each one of these that you will need to get to.
dDUBb is offline
post #3 of 15 (permalink) Old 12-19-2010, 02:36 PM
Same way you remove the radio, din removal tools. Bent wire coat hangers work too.
post #4 of 15 (permalink) Old 12-19-2010, 02:42 PM Thread Starter
stingu's Avatar
^^ can I do this without taking out the surrounding plastic using those small holes on both sides? - I meant the din removal way
stingu is offline
post #5 of 15 (permalink) Old 12-19-2010, 02:55 PM
Yup. If you havn't done it before use the tools(or U shaped coat hanger wire) put them through the slots and push them outward while pulling both out. The whole assembly should slide out.
post #6 of 15 (permalink) Old 12-19-2010, 03:10 PM Thread Starter
stingu's Avatar
Thanks Matt, I'll try to do it tomorrow
And one question not related to the topic - the tail lights - the one with tbird on it - are they supposed to work, cause I dont see any place to put any bulb in there..
stingu is offline
post #7 of 15 (permalink) Old 12-19-2010, 03:13 PM
13's or Mildly Broken
They should light up, yes. They are LED panels. Chances are, they are either burnt out or very dim and hard to see. Also, maybe double check that they are plugged in. Not likely, but possible
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #8 of 15 (permalink) Old 12-19-2010, 03:19 PM
They use LED strips sealed inside the assembly, the easiest/cheapest way to fix them is to replace them unfortunately. They fail pretty often too.
post #9 of 15 (permalink) Old 12-19-2010, 03:21 PM Thread Starter
stingu's Avatar
they are not plugged in, cause i can see wire attached to reverse lights, but I cant find any plug :-/
stingu is offline
post #10 of 15 (permalink) Old 12-19-2010, 03:38 PM
Earl's Avatar
Reverse lights use regular bulbs there is a separate plug for the LED panels
Earl is offline
post #11 of 15 (permalink) Old 12-19-2010, 03:53 PM Thread Starter
stingu's Avatar
thanks guys, I thought it was an option or sth, I've found the plugs hidden in some gaps, plugged in and now it works perfectly!
stingu is offline
post #12 of 15 (permalink) Old 12-19-2010, 05:18 PM
heh, that's some luck!
post #13 of 15 (permalink) Old 12-19-2010, 06:14 PM Thread Starter
stingu's Avatar
it sure is, now it looks awesome, but I have no idea why someone would unplug those LED lights?!
stingu is offline
post #14 of 15 (permalink) Old 12-19-2010, 07:07 PM
To save wear on them so that you could plug them in at a later date and enjoy them.
post #15 of 15 (permalink) Old 12-20-2010, 10:06 AM Thread Starter
stingu's Avatar
Haha, I wouldn't mind
stingu is offline
